b25/b27 engine numbers
steve_k
Mon Jul 19, 2010 9:26 am
right then folks i hope you can help me.
where abouts on a m20b25 should i be looking for the egine number? i;e the one which tells me if it's a b20 - b25 - or b27?
i've heard romur's it's on the bottom of the dip stick, or is that the wrong place?
alo if any one has the numbers then please post them up.
TIA
steve.
Mon Jul 19, 2010 9:36 am
Flat machined area near the LH engine mount. Type number will start 20 ,25 or 27.
steve_k
Mon Jul 19, 2010 9:38 am
Brianmoooore wrote:Flat machined area near the LH engine mount. Type number will start 20 ,25 or 27.
:thumb: thanks brian :thumb:
**BANNED**
Mon Jul 19, 2010 11:25 am
Essentially,there are only two blocks,80mm bore and 84mm bore.
B25/27 are almost identical,the B27 has 'steam holes' between the bores,not essential as the B25 does not have them....
For the very best stroker build you need to start with the un-wanted B20,and have it bored to suit your pistons,more costly overall,but gives a perfect cylinder face.
........and an 320i engine number...... :D
Youth is wasted on the young.
yellowmellow
Tue Jul 20, 2010 8:22 am
DAMN I thought the best combo for a 2.7 conversion was an ETA bottom end with 2.5 head. That,s where I was heading (no pun). :cry:
Tue Jul 20, 2010 8:42 am
yellowmellow wrote:DAMN I thought the best combo for a 2.7 conversion was an ETA bottom end with 2.5 head. That,s where I was heading (no pun). :cry:
It's a cheap and effective combination, but by no means the 'best'.
m_jermyn
Tue Jul 20, 2010 9:05 am
You mentioned the the number would start with 20,25, 27....... This is my engine number whats that mean then 23714009?
mrLEE30
Tue Jul 20, 2010 9:13 am
its a M20B23 from a 323???
m_jermyn
Tue Jul 20, 2010 9:21 am
Nope its ETA
mrLEE30
Tue Jul 20, 2010 10:04 am
ok!
**BANNED**
Tue Jul 20, 2010 10:34 am
The difference is inside the block...
Eta 84mm bore,just like a 325.
But has a longer stroke crank.
I used a standard eta short motor with a 731 head for my build.
If I was to build another stroker M20,I would be going 2.8.
yellowmellow
Tue Jul 27, 2010 7:42 pm
I just need to need to check out some of my part,s/engine numbers. Then ask you a few more questions- If that,s ok
Chees :?
