etch primer
Phatz
Sat Jun 19, 2010 11:58 am
I've been advised by a couple of zoners that etch primer is the best product to spray directly onto bare metal during repairs etc.. followed by other "build" primers and 2K paint.
My question is what is a good brand of etch primer to use? And where to buy?
The Sport - Gone to a new home to be slowly brought back to life :)
StefanAnghel
Sat Jun 19, 2010 3:35 pm
never used them but they can deliver
http://www.frost.co.uk/item_Detail.asp? ... tName=Self Etch Primer (453 g)
http://www.frost.co.uk/item_Detail.asp? ... tName=Self Etch Primer (473) US pint
m_jermyn
Sat Jun 19, 2010 4:29 pm
Just make sure you use a reputable brand mate, etch is etch it all does the same thing... IF you have never heard of the brand dont use it and make sure its suitable for 2k paint.
Phatz
Sat Jun 19, 2010 6:31 pm
Okay, so who are known as a reputable brand? I've never used the stuff before you see. :o:
Halfords sell U-Pol stuff, which I think is well known. However someone else on here reckoned it wasn't a good product.
powelly
Sat Jun 19, 2010 7:18 pm
U-Pol is good fine. I think we use a Lechler one at work.
Image Le Mans Classic 2006
Bluto
Sat Jun 19, 2010 7:50 pm
DuPont at work (I grab the 1/2 or 1/4 cans left over for home use)
grantfk10
Sun Jun 20, 2010 12:00 am
m_jermyn wrote:Just make sure you use a reputable brand mate, etch is etch it all does the same thing... IF you have never heard of the brand dont use it and make sure its suitable for 2k paint.
I don't want to seem pedantic, but read your post - it just doesn't make sense.
addictedtoe30
Fri Jun 25, 2010 8:35 pm
LOL I just thought the exact same thing
Bluto your a thieving pikey (i do the same winkeye )
Raj_p
Fri Jun 25, 2010 8:44 pm
I've used acid 8 etch primer(u-pol) most of the time, works great, never had an issue with it
Only real men get it done with an M20
Phatz
Sat Jun 26, 2010 6:54 pm
Raj_p wrote:I've used acid 8 etch primer(u-pol) most of the time, works great, never had an issue with it
I picked up this stuff today. If I were to apply this followed by the U-pol high build primer, would this leave a surface that would be suitable for 2pack paint?
I only ask as it doesn't specify on the cans and iirc it says 1K on the acid primer.
m_jermyn
Sun Jun 27, 2010 12:59 am
No and yes....
What are you painting? If its things that cant be seen and finish is of no real concern then yes...
If it is the cars body such as a door you might want to us a high build primer over the etch..... Read X-works thread in the stickys on chat part of this forum...
Phatz
Sun Jun 27, 2010 10:02 am
This will really be for parts that won't be seen at all. I just want a decent(ish) finish, but above all I want it to be as rust resistant as possible.
m_jermyn
Sun Jun 27, 2010 10:10 am
Well then it is fine to etch then paint directly over the etch... No need for a high build primer.. We only use the high build primer to fill in imperfections then it gets sanded smooth for final paint coat..
Only use high build primer on outer panels or repairs..
Phatz
Sun Jun 27, 2010 10:14 am
Okay so if I used U-pol acid etch (1k) followed by paint. Then after the the repairs have taken place, get a sh*t load of waxoil in there. :)
m_jermyn
Sun Jun 27, 2010 11:25 am
yes mate that is correct... I assume you are fixing some sort of rust?
Phatz
Sun Jun 27, 2010 11:43 am
You could say that.....
http://www.e30zone.net/modules.php?name ... c&t=132392
Looking for the best way to prime, paint and seal the metal frame work areas underneath where the new roof will go.
SGP
Mon Jul 26, 2010 12:53 am
Hi, I'm doing the same job, so far I've ground as much rust as possible out, and treated the bare metal/remaining rust pitting - with Loctite rust remedy. On the front frame,( had to remove fan etc. in order to get at it). I'n not sure what's best primer to use; the etch wont work through the rust-remedy. I've heard Tri-flow is good for holding back rust. in unseen areas. Any further info appreciated.
If it ain't broke..
Fix it till it is :)
SGP
Tue Jul 27, 2010 2:06 am
I found more rust today, hiding under the joint-sealer in both wheel arches. Oh ! The joy of it all :cry:
If it ain't broke..
octanejunkie
Fri Jul 30, 2010 1:11 pm
Zinc 182 primer is pretty good for pitted/damaged metal. Its good and thick, and as the name suggests, has a high zinc content.
Must be left to dry thoroughly before painting over.
That etch primer from Halfrauds is pretty good.
I bought a tin of etch primer from my local specialist, and it clogged up after a few sprays and was useless.
Halfrauds stuff, despite costing a fortune, is really good.
