Has anyone else experienced this? does anyone have any tips?? and I have tried tightening the belt.
Please help... viscus fan nut!!
charlE30
I'm taking the head of my 325 to replace brocken rockers and everything was going fine until I tried to remove the fan
I'm aware that it's a left threader and that I need to turn it clockwise to undo, I've even bought the special 32mm spanner. Every time I give it a sharp tap the belt slips allowing the whole thing to rotate.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
is it possible to clamp a set of grips onto one of the auxillary belt pullies, without buckling the pulley too much? I'm sure I did that at one stage when I did the cambelt change
300mm length of 25mm X 2mm flat bar.
Drill a 6mm hole near one corner.
Remove one of the pulley bolts and replace it with the flat bar included. (May have to use a slightly longer bolt.)
Turn pulley with 32mm nut untill flat bar locks up against the pulley, and then unscrew fan.
charlE30
I've tried the grips on pulley-didn't work for me.
Brian I like your thinking, I'll give it a go if I can find a suitable bar
It's really frustating as the previous owner had a lot of head work done including new fan?? and I thought it was going to be easy
Cheers for the tips peps.
UPDATE.
I found the perfect bar bolted it to the pulley and.... it sheared off, not really a problem once I finally get the fan removed.
I'm now going to try wrapping my oil filter tool around the part between the pulley and fan....
Am I definetly going the right way- clockwise looking from the front of the car???
UPDATE.
BMW F31 335d xdrive
BMW F31 335d xdrive
Some muppet probably loctited it on!charlE30 wrote:I've tried the grips on pulley-didn't work for me.
Brian I like your thinking, I'll give it a go if I can find a suitable bar.
It's really frustating as the previous owner had a lot of head work done including new fan?? and I thought it was going to be easy![]()
Adammcf
When taking my engine apart for the first time when the head went it took me about 5 hours to get that bloody nut off.
It took lots of heating plus me holding it with grips as tight as I could while a mate hit it with a hammer as hard as he could.
charlE30
Yep I'm now starting to think they used Loctite or fcuking super glue
not!!
All done, cheers for the tips
BMW F31 335d xdrive
BMW F31 335d xdrive
