One side rubs...
Post Mon Sep 19, 2005 2:27 am
the nearside rear wheel catches on the arch when 4/5 etc...
offside doesnt come close tbh.. and looks like it sits slightly further in
got new trailing arm bushes in there (GSF)
any ideas?
TW166Y
Post Mon Sep 19, 2005 2:38 am
fooked shocker?
Saying goodbye to 4-pot wrongness
charlE30
Post Wed Sep 21, 2005 6:46 am
I've got the same problem on mine and it's had new shock's, spring's and all the bushes replaced with powerflex items.
BMW F31 335d xdrive
Post Fri Sep 23, 2005 3:36 pm
all shocks/springs are fine
you can see the wheel sits differently in the wheel arch
Dan318-is
Post Fri Sep 23, 2005 3:42 pm
charl e30 do both sides of yours rub or just the one?
maybe one person is fat 8O
johnno try bushess my mate had this on his e-dirrty-6, was bushes in the end but he replaced struts at same time so could be them too
let us know, as i think i also have a bent strut at the rear due to excessive negative camber
TW166Y
Post Fri Sep 23, 2005 4:57 pm
im pretty sure that there is an overflow bottle on the rear end, cant remember what side its on but i can remember its near the rear wheel arches, maybe this has dropped down? failing that try and have a look to see if the plastic sheild has fallen out of place because mine was making a rubbing sound and i though "fcuk me what now" i took it to local machanic and he simply told me that it must have worked its way free and it dropped down just enough to catch my rear tyre and was making a horrible catching sound, further inspection reveiled it was the plastic trim that simply needed to be screwed back up. just have a look dude maybe you have the same problem..... dont know what else it could be, especially with you saying the wheel sits differently, maybe somthing has collapsed??? sorry if none of the above helps but i will try :wink:
johnono
Post Fri Sep 23, 2005 5:25 pm
are the bushes located properly? what about the hubs? Alloys may be of a different ofset!!!!! that may well be it!
m3 alloys, did they have a wider offset at the back to compensate for the wider arch? i dunno , just guessing ;)
Post Fri Sep 23, 2005 5:29 pm
yeah the wheels are et20..
the issue is - one side fits fine, the other rubs when you've got a load of stuff/ppl in the car ie v compressed suspension
johnono
is there adjustable track on the m3 gear?
TW166Y
Post Fri Sep 23, 2005 5:35 pm
i can hear the chirpy sound of a grinder coming along! take 10mm off it and seal it back up, job done winkeye
johnono
Post Fri Sep 23, 2005 5:47 pm
http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
Jhonno, have a look ;)
is the camber adjuster something that would help?
