hi there
i just bought total bmw and there is a guy who has a turbo'd 325
he is also using 4pots from rx7 have any of you guys heard of this? and if so is it much hassle to fit them ?
mazada rx7 4 pots
stup86
I'm in the process of fitting some to my (soon to be) M50'd E30.
The bracket is simple to make and can be used with Corrado G60 discs (either the discs need the centre bore opening by 1mm to 66mm, or the hubs machined down by 1mm to 65mm)
Parts needed:
M40/M20 ignition coil with high voltage lead
DHFiS
Standard BBS wheels dont fit up to the wheel hub with the RX7calipers fitted so you will need something with a bigger offset and spacers.
nm1
hi there i have 17 azevs and was thinking of putting on 16 by 9 borbet a's would the rx7 calipers fit under those, i seen the calipers for sale for £100 is that cheap?
DHFiS
£100 seems about average. KeriWMS on here does a big brake kit.
driftmonkey
I've got a set knocking about in the garage, never got round to fitting them tho. Might be up for selling them if interested.
