Just going through my engine loom on my m50 using willnz wiring layout stickie, on the m50 side pin10 has a brown cable with a black tracer, his diagram shows no cable there, do i cut it out or does it have a use?
The motor and loom came from a 95 525 manual tourer.
m50 engine loom question
toecutter666
toecutter666
Ok thanks Will, have be trying to find some wiring diagrams on line but didn't find much.
toecutter666
Nice one, thanks. Won't cut it off completely just in case.
toecutter666
Me again, still wiring
on your diagram you show for the engine check light on the e30 a grey wire on pin 12, i have nothing in pin 12, the e30 is a 91 325 manual cab. cheers
toecutter666
Doh! what a dumbass, going through the list willnz put up i've noticed i've got a couple different colors to his and the gauge of wire is not the same either, should i still wire it to the pin numbers and disregard the colours?
Ta
Ta
toecutter666
Cheers will your a life saver, i've got a manual but it lists the colours you have put up. May be i'm just being dense.
toecutter666
Ok got the pin and colours from the e30 side -
1 - Blue
2 - Blue/Black
3 - Nothing
4 - Brown/Purple
5 - Black/Brown
6 - Green/Yellow\
7 - Green
8 - Yellow/White
9 - Black
10-Purple/Green
11-White/Blue
12-Nothing
13-Purple/red large gauge cable
14-Blue/Yellow
15-Black/Green
16-Nothing
17-Nothing
18-Black/Yellow Large gauge cable
19-Nothing
20-Red/yellow
I'll get the E34 colours to you as soon as i can
1 - Blue
2 - Blue/Black
3 - Nothing
4 - Brown/Purple
5 - Black/Brown
6 - Green/Yellow\
7 - Green
8 - Yellow/White
9 - Black
10-Purple/Green
11-White/Blue
12-Nothing
14-Blue/Yellow
15-Black/Green
16-Nothing
17-Nothing
19-Nothing
20-Red/yellow
toecutter666
The e34 colours are the same as you have posted in your stickie
toecutter666
Cheers Will, thats my weekend sorted then
toecutter666
Got another question, should i use the alternator cables from my e30 or use the m50 engine loom ones? i'm installing the battery in the boot if this makes any odds,
