Cypriotgeeza wrote:Gearbox
Dont want to p1ss on your bonfire but thats NOT an M30 gearbox and it wont fit.
Only joking
Good luck
you and me both man!Rav335uk wrote:Lee you fu cker!!, you nearly had me going, I looked, and looked again, and again.
Cypriotgeeza wrote:you and me both man!Rav335uk wrote:Lee you fu cker!!, you nearly had me going, I looked, and looked again, and again.
i will do once im driving it properly! here are the pics:zaust wrote:Get a sound clip up with the pic's.
I think it is.. it looked longer on the car and the gear linkage/ gearstick sat back a bit further then where it is now but next to each other theres not much in itleeparkes wrote:Is the Franky gearbox the same length as the E34 one, ie did the prop fit ok?
leeparkes wrote:
its the way my manager was like "They dont look very different if you ask me" haha its the fact that i dont know where or what it came from that got me..Rav335uk wrote:Finally , the 2 sat side by side look minutely different.
cheers mateleeparkes wrote:iirc M20 idle valves are the same as M30, might help your hunt for one
Double check the part numbers though.
it idles fine its when i rev it i get problems..like i said before if i rev it past 1,500 it will just fluctuate by around 500 rpm so i started unplugging things..when i unplugged the ICV i could rev it normally...also when i shake the ICV it feels like evrything is loose inside..is that normal?leeparkes wrote:Why do you need a new ICV, if you got a dodgy idle it could be an air leak.
Dont forget youve had the head off and disturbed a lot of things
