M52 thermostat
Rallyprep_UK
formerly Driftnething
Post Thu Jul 01, 2010 10:29 pm
Didnt I read somewhere that you can get different temp thermostats ?
I have done a search but cant seem to find what I want :?
I am guessing A lower temp one is needed ? I have an E36 323 rad from a A/C equipped vehicle. My engine is a M52b28 and will be used for track only and will always be run to full temp before use.
I pulled the old part out and it says 92 deg c on it.
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
nickso
Post Thu Jul 01, 2010 10:31 pm
you get an 88 degree one. if no one comes up with a part number off their head i'll check my receipt for the number.
'88 e30 328i M52 track bint.
Rallyprep_UK
Post Thu Jul 01, 2010 10:34 pm
:D thank you so much !
I want to replace that, the water pump (metal type), the plugs with iridiums, I have a K&N oil filter, good oil and some forte flush. I also have a genuine BMW drive belt.
Anything else I should consider while I'm at it ?
Will
Cook318IS
Post Thu Jul 01, 2010 10:36 pm
Yup, 88*C one is the one you want
11 53 7 511 580 :thumb:
Change the waterpump for one with a metal impellor while you are at it
Rallyprep_UK
Post Thu Jul 01, 2010 10:38 pm
Thank you so much guys :D
nickso
Post Thu Jul 01, 2010 10:44 pm
change the tensioner too. if you get one from ECP or the like check the clearance between the tensioner body and the water pump pulley. mine was touching.....and i didn't notice when i fitted it....only later in a complete fluke spy did i notice. :o
Post Thu Jul 01, 2010 10:50 pm
KWP water pump from ECP is the one to use, alloy stat housing is a must
Part number for an 80° stat = 11 53 1 713 040
bumhole
Post Mon Jul 05, 2010 11:07 pm
Hi, I know I have asked this before but I have forgotten what the answer was, sorry!
Is this the same if you have an m50?
I need mine to run a bit cooler on the track.
Ive looked on ECP and got a part code for the water pump of 201110125 is that correct?
What would be the 80 degree stat code? same as above?
