2 new coolant level sensors tried and failed
georgen
Post Wed Sep 21, 2005 12:31 pm
Dudes,
My old coolant level sensor failed on my 325 so I got a new one from ECP. This worked fine, but failed after 3 weeks. Got another one from them FOC and fitted it. Was fine for a day, but has failed again.
The coolant level's fine, any ideas ? Has anybody else had problems with these from ECP ?
Ta
G
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
Post Wed Sep 21, 2005 10:09 pm
First point- There are two different sensors; a fact my nearest GSF branch is unaware of, as they gave me the wrong one once.
Wrong one should give a permanent low coolant warning though (unless the coolant really is low, when it indicates OK).
Second point - Are you sure the sensors really are dud? Sounds like you may have got a wiring fault. You really need to fit one of your "dud" sensors in another car.
georgen
Post Thu Sep 22, 2005 1:02 pm
Brianmoooore wrote:First point- There are two different sensors; a fact my nearest GSF branch is unaware of, as they gave me the wrong one once.
Thanks Brian, I'll try a known good sensor.
01' 330ci Sport
