No spark.. please help need car tomorrow (new cps still no s
bobbin1982
Wed Jun 23, 2010 6:04 pm
Yes im grovelling winkeye
Ok basically my auto gearbox isnt working as it should but i assume it should not affect me getting a spark...
The car has been fine for ages i had a problem of the PCS rubbing on the flywheel before and i replaced the coil dizzy and rotor arm and installed new plugs before i found the problem... so these SHOULD be fine..
I was driving home after shopping and the car just died at a pedestrian crossing. I got a tow home and first thing i checked was PCS but seems to be not rubbing on the flywheel as before...
Has anyone got any ideas what i can check?
I really need the car for work tomorrow
Thanks, Andy
Driving my digger!!!!
Wed Jun 23, 2010 6:14 pm
I would rule out the gearbox Andy as (unless I am wrong) the inhibitor switch under the gear selector prevents the car from even turning over unless you have it in Park when trying to start. Can't see anything else gearbox related stopping it from getting a spark.
Be careful towing the car (i know it can't be avoided) for any distance as autos do not like being towed.
Prime suspect has to be the wire from that crank sensor which was getting chewed. What is to say the wire isn't broken inside?
bobbin1982
Wed Jun 23, 2010 6:20 pm
no you are right it could be chewed it looks pretty chewed to be honest but has been working fine for a couple of months
... any way around this?... can i join a peice between or anything?
As i say im desperate lol
Andy
Wed Jun 23, 2010 6:27 pm
I would say if you can splice some wires in there as a temp measure, maybe it'll work as a temp bodge/ get you to work fix.
I'll have a look in my parts stash, pretty sure I have a M20 crank sensor with all my scrap, if I do (not knowing if it works or not) I'll post it to you fella.
bobbin1982
Wed Jun 23, 2010 6:33 pm
Ok ill give tghat a go...
Your a gent..want anything for it?..
I thought it was part of the HT leads? and not seperate
Andy
Wed Jun 23, 2010 6:43 pm
These are what I have Andy, not sure if these may be from the earlier motronic setup where the sensors are on the flywheel end rather than at the front of the engine like yours will be
If they are any good and look the same as what you have, you can have them FOC
bobbin1982
Wed Jun 23, 2010 7:20 pm
bummer mine is different..no problem though it was a kind thought you had
Ill hope wilco or gsf or ecp have one in or can get one..
This look likely to be the cause? :eek:
I think im gonna re-route the new one :roll:
by the way im not even gonna try and splice this.. looks fooked
Andy
Wed Jun 23, 2010 7:42 pm
I have just had a look on both GSF and ECP websites and can't find any crank sensors listed, so I would doubt Wilco will have them.
You don't even want to guess the price from BMW, but it is probably 3 figures.
I would put a wanted ad up on here mate, hopefully someone will be able to get one to you before the weekend.
bobbin1982
Wed Jun 23, 2010 8:36 pm
looking at mine though it seems the wires arent actually cut through its just took a lot of rubber away..
I put some insulation tape around it and re-routed it in front of the dizzy and still nothing.. is there anthing else that could be the problem or any checks before i cry myself to sleep cos i have to miss 2 days money at work :cry:
Cheers beemerlad
town325i
Wed Jun 23, 2010 9:18 pm
I have one £20 posted
luke4073
Wed Jun 23, 2010 9:25 pm
i had same prob few months ago had a break in the wire between crank sensor and ecu routed new wire and has not let me down since not sayi it your problem but worth a look i supose :)
bobbin1982
Wed Jun 23, 2010 9:28 pm
well yes all options are taken on..you have a picture of this?..or even better can you come show me? hah
Andy
luke4073
Wed Jun 23, 2010 9:33 pm
i can come show u if u need me to :). on mine it was the wire from the crank sensor plug back to the ecu
bobbin1982
Wed Jun 23, 2010 9:40 pm
Yeah why not.. pop over and say hello.. nice to meet fellow zoners and all that (plus i want to see your car)
:wink:
Pm me with when your about this weekend
Andy
town325i
Wed Jun 23, 2010 9:51 pm
TBH judging by the state of that wire its definattly you crank sensor
bobbin1982
Wed Jun 23, 2010 9:54 pm
Yeh is a little mullered to say the least :mad:
I did strip the outer casing off and find just 2 wires though with no breaks in the copper and i wrapped insulation tape round each wire induvidully and then taped together but still no joy unfortunatly
Andy
b17
Wed Jun 23, 2010 10:00 pm
luke - bobbin - wouldn't mind meeting up with fellow zoners too as I'm in Norwich and would like to see a working e30! Mines forever being tinkered with....
bobbin1982
Wed Jun 23, 2010 10:26 pm
Mines not exactly working :mad:
But yeah im fine with it ... Think me and luke are meeting sunday at mine
Where abouts are you in Norwich? Pm me to save spamming the thread
bobbin1982
Fri Jun 25, 2010 3:23 pm
Ok put the 2nd hand CPS on and still no spark...
What do i try now?....coil pack?
Andy
bobbin1982
Fri Jun 25, 2010 5:24 pm
just changed coil over to a spare and checked dizzy.. all seems fine..
bobbin1982
Fri Jun 25, 2010 5:26 pm
suppose im gon na have to tryyour theory luke..
Would a dodgy ecu cause this?
vokietis
Fri Jun 25, 2010 10:03 pm
must be ecu...
bobbin1982
Sat Jun 26, 2010 1:12 am
How do i perform the basic checks?
I dont have a multimeter
baptie0
Sat Jun 26, 2010 1:27 am
all you need is a 12v bulb and some wire, then you can check for a feed & earth. 8)
luke4073
Sat Jun 26, 2010 8:35 am
or i can bring one over sunday :)
bobbin1982
Sat Jun 26, 2010 10:17 am
luke that sounds like a good idea mate... i hate electrics and dont know anything about them
Sat Jun 26, 2010 10:20 am
Stop swapping, and get testing!
bobbin1982
Sat Jun 26, 2010 10:25 am
I will purchase myself a multimeter in the week at some point.. hopefully me and luke can get her started sunday
Sat Jun 26, 2010 10:49 am
90% of testing is best done with a simple 12 volt bulb. I use an indicator repeater bulb, holder and lead, with the plug cut off.
bobbin1982
Sat Jun 26, 2010 11:28 am
i know what ill be doing next time im up the scrapyard then ;)
luke4073
Sat Jun 26, 2010 1:00 pm
ive only had 2 probs with ma car in 2 years and both were down to brittle/broken wires :( but in a car 20 + years old i dont expect anything else. not saying it could be ya problem but anything worth a try :)
bobbin1982
Sat Jun 26, 2010 3:57 pm
hopefully we will find the problem tomorrow :)
DBB83
Fri Jul 02, 2010 5:03 pm
Did you get this fixed?
It could be the same issue as mine -
I am going to take my flywheel off next week and see if I can find a replacement.
What year is your car?
1987 E30 325i Sport
1998 Audi S4
