inspection light
fender182
Thu Jun 24, 2010 2:56 pm
just a quick one..
just had the inspection light turn on in my car, so im gonna give it a service at the weekend. will the inspection light turn off or will i have to take it to a bmw specialist or similar garage to have it turned off?
cheers
jamie
2.1 318iS E30 - Weekend toy (2.8 loading...)
330Ci M Sport E46 - Work horse
335i M Sport F30 - Family car
**BANNED**
Thu Jun 24, 2010 3:02 pm
You will require a re-set tool to put the light out.
I bought one via E-bay some years back for about £12.
You can use a bit of wire to the correct pins in the diagnostic socket,but I struggle to read the pin numbers there and cannot remember which one's anyway!
A hunt through the wiki,link at the top of page,may just give you an answer.
Youth is wasted on the young.
mrLEE30
Thu Jun 24, 2010 3:41 pm
if you look in the diagnostic socket inside the engine you need to locate pin 7 pin numbers are next to thier respecive pins, but very small assuming you have the later engine, older engine the pins are identifie inside the red cap.
ignition off then ground pin 7 then turn ignition on and wait about 5-7 seconds and the lights shoudl reset to green. to reset the orange oil inspection light turn ignition off and back onn for 5-7 secs and this light will extinguish. remove the ground and job done. If the lights do not reset you have the wrong pin or the service batteries are flat
Falkster
Thu Jun 24, 2010 5:07 pm
Just buy the tool mate, so much easier! Eurocarparts sell them if you don't want to wait for ebains!!
fender182
Thu Jun 24, 2010 5:56 pm
Cheers people, probably just get the tool when buying the service parts.
finluxsuperstar
Thu Jun 24, 2010 6:43 pm
whats it called on ECP, cant find it online
cheers
brent007
Thu Jun 24, 2010 7:12 pm
http://bmw.phisk.net/Documentation/E30/ ... ervice.pdf
or
http://cgi.ebay.co.uk/003-Oil-Service-L ... 335dbd2212
i do it myself with wire, its dead simple, afew guys on here showed me how
ITS ALL ABOUT BEING DIFFERENT
poolnoodle
Fri Jun 25, 2010 6:32 am
Go with the wire - very simple and cost nix
Fri Jun 25, 2010 9:08 am
Pin 7 is extremely easy to find - it's the one on the outside right in the middle of pacman's mouth.
Earth it on a body earth (e.g. rear bonnet bracket), so that you don't have to bother identifying the earth pin in the socket as well.
