Frankenstiens creation...
Cypriotgeeza
Wed Jun 16, 2010 9:16 pm
Getting it in at work friday to do the clutch but i still have the idling problem.. Now it wont idle and when i keep the revs at about 1,500rpm it keeps fluctuating from that to around 2,000rpm on its own..
im thinking either maybe tps like Rav said---but i never took it off?
or maybe a breather sucking in air?
has anyone come across this before?
Check my M30 build threads:
Wed Jun 16, 2010 9:18 pm
How long was the engine sitting for?
And when you turned it over, did you leave it to idle on its own??
Cypriotgeeza
Wed Jun 16, 2010 9:20 pm
Engine was sitting for about a month, and yes yesterday when i fired it up it was idling ok'ish, just whenever i touched the throttle it would cut out
Wed Jun 16, 2010 9:36 pm
TPS or take the battery off overnight, connect up and start the engine, leave it to idle without touching the throttle for about 10 mins, IIRC, the ecu needs to "Learn" again.
Cypriotgeeza
Wed Jun 16, 2010 9:39 pm
problem is it starts but then cuts out straight away, reason why im thinking its a dodgy breather or maybe my idle control valve is faulty? my i.s icv valve looks the same, i might jus put it on to see if it makes any difference..
Wed Jun 16, 2010 9:44 pm
Try the air leak concept, then the tps, if that fails, try my method.
Cypriotgeeza
Wed Jun 16, 2010 9:45 pm
will do mate! thanx :thumb:
Cypriotgeeza
Sat Jun 19, 2010 10:58 pm
i also forgot to mention that i went and done a bit of shopping the other day at my local E30 parts place -->"E30partz.co.uk" and picked these up :
--2 Good wings
--A 325i front cross member
--An E34 washer bottle
--An E34 airbox
--A Radiator bracket as mine was held on my cable ties :mad:
Cypriotgeeza
Fri Jul 16, 2010 8:26 pm
Hey guys, as you all know im having problems with the way my cars running and thought id record it so maybe someone could shed some light on what the problem is :mad:
one of my mates said his e30 used to make the same noise and it turned out to be a snapped Exhaust manifold stud which was sucking in air into the engine..i know none of mine snapped but i do know i put the manifold gasket in upside down, :o: could this be the problem?
Any help would be great peeps!
Heres the vid:
http://s81.photobucket.com/albums/j215/ ... V03413.mp4
Cypriotgeeza
Fri Jul 16, 2010 8:46 pm
ok so i just watched this and he said it was his ECU 8O
zaust
Zone day release
Fri Jul 16, 2010 8:51 pm
have you rest the tps correctly ?
M30 Tech 1 Touring on gas.
Yo sure your TPS isn't knackered???
And get that Cone filter OFF!!!!!!. they're shit, all you'll be doing is suking in Hot air of the exhaust manifold. Put the origional E34 on back on , it's shieled to protect it from heat.
Cypriotgeeza
Fri Jul 16, 2010 8:56 pm
Yep i know Rav i tried to fit the airbox i bought but it wouldnt fit because need to cut the coil pack brackets off due to the car originally being a iS and i cant do that untill i get it in at work again..
i did what you said with the tps but there was only one click when i just opened the throttle..there was no second click when it was fully opened :? maybe thats knackered?
Fri Jul 16, 2010 9:19 pm
TPS then, should have 2 clicks iirc, one at WOT and the other when the throttle position is slightly engaged.
Cypriotgeeza
Fri Jul 16, 2010 9:21 pm
yep mine definantly only has one click when it is slightly engaged..no matter how i adjusted it there was no second click :? maybe its time to look for a TPS? :?
Fri Jul 16, 2010 9:23 pm
I'm sure you can check it via volt meter.
Put it up in the tech section, Will and Mr Moooore are on there now.
Cypriotgeeza
Fri Jul 16, 2010 9:24 pm
i have a multimeter at work so i will bring it home and try tomorrow..
will do that now :thumb:
Cypriotgeeza
Fri Jul 16, 2010 10:51 pm
a lot of help that was haha i guess its the old fashioned brake cleaner method
Fri Jul 16, 2010 10:56 pm
What, no good, or did you get directed to the voltmeter?
Cypriotgeeza
Fri Jul 16, 2010 11:14 pm
i think we got lost in translation mate :mad: i just looked in my haynes manual again and it shows how to adjust the tps with the voltmeter...only problem is it says "if the readings are incorrect adjust to correct settings" which it does not tell you what the actual reading should be :mad:
Fri Jul 16, 2010 11:16 pm
Haynes does lack some vital info :mad:
Cypriotgeeza
Fri Jul 16, 2010 11:21 pm
bigtime! i will do some more investigating tomorrow or sunday and let you guys know :thumb:
zaust
Zone day release
Sat Jul 17, 2010 9:34 am
Mate I had a think about this, The tps can only give you a flat spot and cause incorrect reving, It would not make your engine hunt like that. Give me 5 I want to do a cross ref on something and confer with a mate I will pm you.
Cypriotgeeza
Tue Aug 17, 2010 1:47 pm
ok guys after a NEW TPS and a bit more investigating im STILL having the same problem :cry:
getting quite annoyed now as i cant find an air leak and i cant figure out what it is..
Im thinking now maybe its a faulty "blue temp sensor" or maybe a dodgy earth or something? really am running low on ideas or motivation tbh :(
Wondering wether to take it to a BMW expert and asking him to take a look?
Tue Aug 17, 2010 8:26 pm
Just got back from Holiday, have you changed the Blue sensor?
charlE30
Tue Aug 17, 2010 9:00 pm
Try a know good AFM meter, my other halfs tourer had similiar problems and changing the AFM resolved it completely
BMW F31 335d xdrive
Cypriotgeeza
Tue Aug 17, 2010 10:02 pm
that was my next two things i thought about changing..just getting annoyed with the money being thrown at it atm..if it fixes it i wouldnt mind so much but nothing is working :-x
charlE30
Wed Aug 18, 2010 4:49 pm
Where abouts in the country are you? if your local to me you could try mine to see if that cures it :D
BMW F31 335d xdrive
leeparkes
Wed Aug 18, 2010 10:42 pm
iirc he's down London way
Cypriotgeeza
Tue Aug 24, 2010 8:19 pm
Ok guys slight update..I bought a good AFM and tried it today and for once the revs dropped to around the 1000rpm mark which was a good sign..now ONLY when i rev it past 2000rpm it starts doing what it does in the video i posted..
so i started messing around with things (again) and if i disconnect the ICV it makes no difference to the revs and i can rev it up perfectly which makes me near certain about it not having an air leak..
so i changed it back to the (known good) second hand one i bought recently and it does the same thing.. :mad: :?
i have 12v to both the outer pins of the connector which goes to the ICV...
im wondering wether to fork out on a brand new one now? really am frustratingly close to figuring this out!!
craigieeb
Tue Aug 24, 2010 8:30 pm
I'm just gonna throw this one in the air...
are the connections the same on the T.P.S and the ICV...................??
Cypriotgeeza
Tue Aug 24, 2010 8:32 pm
both have three pins..
Cypriotgeeza
Wed Sep 01, 2010 8:49 pm
craigieeb wrote:I'm just gonna throw this one in the air...
This made me think..and i realised that they do have exactly the same shape and amount of pins so i swapped them around and PRESTO its fixed now! :o: :o: i cant believe it was prob just that the whole time! I feel like such an idiot! :o:
Jus need to get it taxed and insured and its ready to roll!!
leeparkes
Wed Sep 01, 2010 8:51 pm
:clap:
Cypriotgeeza
Wed Sep 01, 2010 8:52 pm
:o: its a bitter sweet victory as i feel like a proper muppet now haha least i have a few spare parts 8)
