S50B32 Fuel pump problems (e30 m3)
MrBenn
Post Wed Jun 16, 2010 9:56 am
I'm having a bit of a problem with my fuel pump. I modified the original intank pump to accept the s50b32 pump and got everything running fine. After a few tests it stopped working and it turned out the small rubber reducer I had used had split down the middle, presumably down to the 5bar pressure. So I replaced this with a much thicker bit of rubber tube and everything seemed fine. Finally got the car Mot'd and on the road, took it for a spin and after about 45 minutes or so of driving the fuel pump disconnected meaning I had to be towed home by the AA (long range tank was full of fuel meaning I'd of had to syphon off about 15-20 litres of fuel just to get the pump out). So after two failures I'm thinking this is not the way to go. Should I replace the original intank pump and fit a 5 bar external?
Cheers,
jmc330i
Post Wed Jun 16, 2010 10:05 am
MrBenn wrote:Should I replace the original intank pump and fit a 5 bar external?
Others have run the B32 pump in the E30 carrier without problems. It may of just been the pumps time??
From memory, some have fitted a Walbro pump into the E30 carrier. Not because its any more reliable, but because its cheaper than a B32 pump.
James
'91 325i Sport
'93 318i touring 16v
HenryM3
Post Mon Aug 16, 2010 8:04 pm
the tubing your using is I presume suitable to be immersed in fuel. My first attempt failed after a short time, got some tubing out of a 5 series tank an its been fine for years.
RoadHazard
Post Tue Aug 17, 2010 8:06 am
I replaced my intank fuel pump with the Walbro one. Turned out that I still have to keep the external pump because the Walbro couldn't provide enough juice. Weird.
UweM3
Post Tue Aug 17, 2010 9:48 am
As HenryM3 already said you NEED the right tubing material.
I didn't want to get into trouble and have just used the whole intank assembly of an E36 B32.
I needed a swirlpot anyway so I combined the two things.
Fed by the low pressure intank pump
made a swirlpot which accepts the E36 assembly
pressure tested to 2bar
and fitted in the boot with an E36 fuel filter
MrBenn
Post Tue Aug 17, 2010 9:56 am
It turned out I had accidentally picked up a peice of servo tubing not fuel line, hence why it only lasted a few days, its since been swapped for fuel line and has been fine so far but I am aware it probably wont last and as has been said above you need proper "in tank" fuel line. Thanks for the tip of where to find some cheap Harry :)
HenryM3
Post Tue Aug 17, 2010 8:37 pm
UweM3 you flash sod
UweM3
Post Tue Aug 17, 2010 9:48 pm
HenryM3 wrote:UweM3 you flash sod
only hitting 2 birds with one stone. Form follows function is my motto. winkeye
