My past 2 days
stup86
Post Thu Jun 10, 2010 4:24 pm
Yesterday whilst at the workshop I got busy making a simple bracket (x2):
Can you guess what it's for???
Maybe this can help, I took delivery of the calipers today:
It's a start, just need some discs, new pads and clean the calipers up. Although with the extra 10hp I get from red calipers I may keep them!
What you think?
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
stixe30
Post Thu Jun 10, 2010 5:56 pm
those calipers look bigger than my forearm!
Post Thu Jun 10, 2010 5:58 pm
Is that going to sit on the disk right? What size/thickness disks will you use?
Should give a nice pedal :D
oakey
Post Thu Jun 10, 2010 5:59 pm
Are these the rx7 calipers? I remember reading the thread in e30 chat about the conversion. What size wheels will you need to run for clearance?
stup86
Post Thu Jun 10, 2010 6:19 pm
Yes they are RX7 calipers
I'll be using VW Corrado 280x22mm discs and a 3mm spacer so the wheel clears the caliper. The discs should sit perfectly central. I modified the design of the brackets so I may still need to 'step' the centre holes for the disk to sit central. Soon tell once I get the discs
They should fit under standard 15" BBS.
I've been writing a how-to of what is needed and i'll upload it once it's finished.
My plan is to use a E32(?) 750 master cylinder with it too.
Parts needed:
stup86
Post Thu Jun 10, 2010 9:13 pm
Is buying a used master cylinder a good idea or should I get a new one?
Parts needed:
inlovewithRWD
Post Fri Jun 11, 2010 12:24 am
stup86 wrote:Is buying a used master cylinder a good idea or should I get a new one?
For what it's worth I'd get a new one. You don't want to take a risk when it comes to brakes.
gcs325i
Post Fri Jun 11, 2010 12:33 am
You may have to offset the caliper holes 2mm from the center of the strut hole's to make it work, also 15" bbs's will require a 12-15mm spacer to clear the inside of the wheel. I used a m3 M/C and the pedal is fine.
