For instance do i really need a water cooled alternator?????
Im running a stripped out manual with loads less electrics than the E34 so???
I have a blown 530i engine as my dummy engine, so i can chop away, i thought id ask before i lept
TIA
... yes and then you've hugely less usability and significantly higher fuel consumption. All carburettors should be melted, those are ancient shit.jay4thecruise wrote:ditch all the fancy electric gubbins n go for 8 bike carbs poking out the bonnet![]()
Yap, but where in the bay?200272 wrote:In the engine bay
I just hit the Jackpot, i picked up a 93 540i, it has the cable acceleratorand no water cooled alternator, as has been said and the best bit its a 6spd manual.
Hey Jonsku do you have any info on the diff setup your using?
