skyway
Post
Wed Jun 02, 2010 11:01 pm
spook wrote:Grommeted, sounds like something nasty one would do to a plasticine dog.
or
Whichever works for you!
HartgeH27
Post
Thu Jun 03, 2010 7:05 am
Superb recovery guys !
Shaheenk
Post
Thu Jun 03, 2010 11:36 am
placey wrote: Blah ... Blah Blahh they are all turned up and regularly driven hard .
Please explain.......
8 gauge is more then fine for the apline aplifiers you have, I would not see them draw more then 40 -50A on spikes which last less then a second. Music is dynamic so you not drawing peak current at all times, the thing about power cable is its all based on distance, the further away the amp is the more sense it makes to run a larger gauge cable. Where you are using a Distro block in the rear you can then go down 1 or 2 sizes to the amps as the current draw and distance is shorter.
placey
Post
Thu Jun 03, 2010 2:52 pm
i'll have to look them up - i've not heard of them before!
should have put this earlier - 8 gauge was used as it was already there and budget constrictions were in force!
i saw a doctor and she gave me some pills....
Shaheenk
Post
Thu Jun 03, 2010 3:01 pm
Oops , should have been Alpine Amplifiers. Like I said , nothing wrong with 8 gauge at all.
mrLEE30
Post
Fri Jun 04, 2010 4:12 pm
to be correct bigger cable does have less resistance due to greater cross sectional area(assuming conductor material is same) but a bigger cable does not give more current, it just can accept more current without getting hot.
The current is dictated by what the amp demands and is limited by the supply available
the main advantage to bigger cable is the voltage drop is less, so more volts seen by the amp will allow it to amplify more.you guys with electrical backgrounds should know this!!!
fowler
- Boost Junkie
Post
Sat Jun 05, 2010 9:58 am
Placey you are a true legend if this sounds any where near as good as your Coupe it will be the nuts....
Ben
EX A-Tech Workshop bitch !!!
gone but not forgotten
bmwsport
Post
Sat Jun 05, 2010 10:01 am
Less with the banter, we need an update with more pics
'85 Hartge H28
oomz1975
Post
Sat Jun 05, 2010 12:38 pm
Great thread, will defo come in handy when I strip the touring soon.
skyway
Post
Sat Jun 05, 2010 1:18 pm
Im doing my touring soon....Ill be doing a few things that no one has thought of yet!
HartgeH27
Post
Sun Jun 06, 2010 8:13 am
All I can say as a layman to the ICE side of life is that the sounds are absolutely superb and this is only phase 1
The build is only constrained by my budget and certainly not by Placey's (Paul) ability.
More work to come which I am sure Paul will post up as and when it occurs.
What a guru !
Post
Sun Jun 06, 2010 9:17 am
Paul mines waiting next! just found the thread
HartgeH27
Post
Sun Jun 06, 2010 9:26 am
Si,
He is more meticulious than you !
