Injector colour (blue , beige)
I've just had a set of injectors refurbished by Injectortune and must say the service is excellent , sent on friday got them back wednesday , I've noticed that the injectors in my 1990 320i are Blue and the refurb ones are beige have i made a booboo? I can't find the thread i read but i'm sure the blue ones are 325 and beige 320 , just wonna make sure before i go head first into the job for the first time ,
yes, no.
This is what I did
1. unplug battery
2.clean around old injectors with carb cleaner so you don't have to do it later and risk gunk going down the holes
3. unplug fuel pressure reg, blue and back temp sens, plug under the manifold and breather hose.
4. remove injector electrics rail
5. remove 4 injector rail screws
6. use a bit of wood to gently lift up the fuel rail and all injectors with it. Move each side bit by bit.
7. slide the rail towards the front and remove the clips and injectors 1 by 1 as you go past cylinder 1.
Install is reverse, put oil on the seals.
This is what I did
1. unplug battery
