Stall on take-off - Help!
Treeman612
Post Mon Sep 19, 2005 12:49 pm
Hi - got a real annoying fault on my 320i - recently disconnected battery for welding work - checking everything over when reconnecting, I found the vacuum hose from inlet manifold to front of engine leaking, so fitted new hose. Tickover now approx 600rpm and steady. When you apply just a whisper of throttle to take off, the engine revs up and down between 400 - 800 rpm, and sometimes stalls. OK if you start off with big wellyful of throttle, but surely something is wrong? - Any clues? IMO it must be either a) throttle position switch, b) Idle control valve or c) AFM. Any advice welcome...
johnono
Post Mon Sep 19, 2005 4:42 pm
mabey u still have a leak, but all of the above are first port of call for sure
E30Adam
Post Mon Sep 19, 2005 5:31 pm
If you disconnect the battery for long periods the ECU has to relearn settings, give it a couple of days to settle down and see if it's still doing it.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
