Braided brake hoses
hoggie
Tue May 25, 2010 4:59 pm
Are braided hoses worth the money in terms of an upgrade from standard hoses.Do they improve braking performance??Or are they mutton dressed as lamb.
bdx
Tue May 25, 2010 5:14 pm
bmw £70 approx for two flexibles, whereas a set of 6 braided £60-70.
spic
Tue May 25, 2010 9:46 pm
If your a hard breaker then there worth the lolly :wink:
Tue May 25, 2010 10:07 pm
The difference between new rubber hoses and braided ones is probably minimal, but between the average E30's hoses and braided ones will be considerably more, and as bdx has pointed out, the braided ones are cheaper.
Jonsku
Wed May 26, 2010 5:30 am
You can buy the brake hoses also from other suppliers than BMW... If you want to spend extra money for braided hoses then go for them, but you won't get any enhancement over standard brake hoses (if they're in good condition).
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Wed May 26, 2010 8:40 am
Jonsku wrote:You can buy the brake hoses also from other suppliers than BMW...
You can, and I have, but don't expect them to last like the genuine article.
aeberbach
Wed May 26, 2010 9:30 am
Coincidentally I just changed my 6 today - replaced them with standard OEM Ate rubbers. No way is a stainless sheath going to make a scrap of difference to braking performance! "Rubber" sounds weak but this is serious rubber.
Saga
Wed May 26, 2010 9:45 am
As someone who has used them for years, they do make a difference to braking performance - sorry to burst your bubble aeberbach!
Essentially, aside from being cheaper, the advantage is greater fade resistance and firmer pedal feel (varies according to the vehicle's braking system of course). There is no other dramatic advantage however. They don't increase braking power, and won't make a patently inadequate braking system which is cooking its fluid something chronic capable of fade-free operation on track.
aeberbach
Wed May 26, 2010 9:57 am
Mmm, OK, but I'm going to file that one with $9000 speaker cables. It's the same basic material inside the stainless braid and if it's loose enough to remain flexible it's not tight enough to stop the rubber from expanding under pressure (which it doesn't anyway. Really, stick a micrometer on the hose and pump the pedal).
AussieM20
Wed May 26, 2010 10:27 am
I fitted HEL Braided hoses to mine, Gave an instant reduction in pedal travel due to a reduction in flex in standard hoses absorbing fluid volume. Don't knock it until you try them.
A common improvement in E36 M3's is braided clutch slave cyl hose to prevent clutch drag, i even think that it may have been a genuine modification.
Regards
Greg
harry_p
Wed May 26, 2010 10:41 am
remember that probably 99% of people who fit braided hoses will be doing so to replace 20 year old rubber ones, so it's not suprising that there's an improvement.
i needed to replace the hoses on my m3 in a hurry and bought new rubber ones as i couldnt wait for braided ones. i do a lot of fast road driving and the odd trackday and the brakes feel great. don't assume that braided hoses will suddenly transform your cars abilities unless your old hoses were knackered
cheers,
harry
hoggie
Wed May 26, 2010 11:18 am
My existing hoses are in good condition,I just wanted to see if the braided hoses made a difference in performance.I might use the £70 on something else cheers guys
Jonsku
Thu May 27, 2010 5:53 am
Yap, but they do last long enough for such an old car as E30's.
I've Goodride braided brake hoses and selfmade braided clutch hose in my cabrio. Haven't noticed any difference in braking performance, though they surely look cooler :P
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Thu May 27, 2010 8:48 am
Jonsku wrote: Yap, but they do last long enough for such an old car as E30's.
What's that supposed to mean! My collection of E30's has lasted twenty years, and I fully intend most of them to be around in another twenty, courtesy of BMW Mobile Tradition.
