Speedo stoped working HELP
woodysjw
Post Fri Sep 16, 2005 8:41 pm
It started jumping about on and off for a while now its
stopped all together but the mileometer still works and so does
my fuel computer thingy 13 button OBC
796 - 1989 Motorsport Edition
stevo
Post Fri Sep 16, 2005 8:44 pm
think theres a sensor on the diff thats prone to braking?
Post Fri Sep 16, 2005 9:00 pm
the speedo sensor unit is on the diff casing at the rear. The 2 wires that go into the connector plug often get brittle and break. If you are lucky they will have broken some distance from the actual plug, that way you can reconnect using a bullet connector etc. Mine broke right where they go into the plug, so I had to scavenge one off a breaker
here's a pic of my diff, speedo connector/ plug is top right - u can see the broken wire
dazleeds
old skool raver
old skool raver
Post Fri Sep 16, 2005 9:06 pm
also if its fixable im pretty sure it uses the same plug as the fogs etc hth Daz
www.oldskoolfantasy.co.uk
woodysjw
Post Fri Sep 16, 2005 10:44 pm
Thanks will get under and have a look in the morning
Post Sat Sep 17, 2005 10:40 am
The wire is usually broken inside the plastic sheath, and can only be found by gently stretching the wire.
The cause is probably the copper becoming brittle with vibration, so I would not recommend a repair using the same piece of wire.
Get a similar connector from a scrappy with a foot or so of wire attached, (one of the headlamp connectors is the same, and the yellow plastic bit can be bought seperately from a dealer if its broken), cut the original diff wire well away from the diff and splice your new wire on using soldered joints and heat shrink tubeing.
mrbless248
Post Sat Sep 17, 2005 9:59 pm
My speedo kept cutting out but the solution was different. The solder on the back of the speedo was cracked, causing it to come on when there was a connection and go off when the connection was broken (by either a bump in the road, heat or cold making the solder swell or shrink).
The best thing to do is follow the instruction on this link (www.unofficialbmw.com/speedo/speedo.html) and that should hopefully solve the problem.
I litterally done it today in about 1 1/2 hrs and now my speedo's fine after some serious testing!!!!
winkeye
woodysjw
Post Sat Sep 17, 2005 10:07 pm
Well replaced plug with a big chunk of wire about 10in joined it all in
the old plug just fell to bits thought that this must be the fault.
drove down the road and nothing.??
Post Sat Sep 17, 2005 10:37 pm
Sorry, should read the OP before answering.
If your mileometer is still working normally, then it's nothing to do with the diff cable.
Must be something to do with the speedo itself. Probably something like Mrbless248 says.
