m3 insturment cluster in a 318is?
Dan318-is
Post Thu Sep 15, 2005 11:12 pm
considering i can find a set, is it a straight swap or a modification job or impossible??
i wont an oil temp gauge but dont wont a sticky plastic one in the way of my dash
n e ideas?
Jimbob
Post Thu Sep 15, 2005 11:24 pm
Yea but it doesn't mean you'll have an oil temp guage just by fitting the M3 clocks, needs a bit more work than that.
Dan318-is
Post Thu Sep 15, 2005 11:25 pm
can you elaborate some more mate?
Jimbob
Post Thu Sep 15, 2005 11:29 pm
The oil temp guage will need something to send the signal of how hot the oil is, which will need to be wired to the sump, you'll have to change the sump plug to incorporate a wire feed.
Dan318-is
Post Thu Sep 15, 2005 11:30 pm
like a special sump plug??
do i haev to make my own or can i buy one? is that the only bit of wiring i need?
Jimbob
Post Thu Sep 15, 2005 11:37 pm
Do a search.
Dan318-is
Post Thu Sep 15, 2005 11:38 pm
thanks
A1BMW325iSport
buy the M3 oil temp sensor from bmw for around 18quid then run the wires from it up to the terminals on back of instrument cluster
Dan318-is
Post Thu Sep 15, 2005 11:56 pm
an where does it go dude the same place the m3 one does?
or is it external from the cluster?
A1BMW325iSport
Post Fri Sep 16, 2005 12:12 am
the m3 cluster has terminals on the back you just run the wires up to it
Dan318-is
Post Fri Sep 16, 2005 12:16 am
does the sensor from bmw plug into the sump then?
also, if i buy some dials im wotchin on ebay that have the speed in km/h n e chance i cud change the fascias so there in mph?
take it i need to swap the coding plugs on my 318is for the one on the m3 cluster also?
A1BMW325iSport
Post Fri Sep 16, 2005 12:32 am
normally it would be fitted in the M3 oil filter housing
the most common method on non M3 models is to fit in place of sump plug
Dan318-is
Post Fri Sep 16, 2005 8:28 am
cheerds dude
i think il try an find an m3 cluster b4 i do n e thing :lol:
karlp
Post Fri Sep 16, 2005 6:46 pm
In the back of the M3 cluster there is an additional 3 pin socket.
One = 12v +
Second = Earth
Third = to sensor.
Karl
Dan318-is
Post Fri Sep 16, 2005 6:48 pm
do i have to make connections for these also dude
E30Adam
Post Fri Sep 16, 2005 6:49 pm
Your fuel guage, speedo and rev counter will also not read correctly.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Dan318-is
Post Fri Sep 16, 2005 6:57 pm
fuc* that then
n e other ideas for oil temp gauge? or shall i jsu get an aftermarket one
