This is really getting to me now, I've fixed one leak but found another now (FFS how many can ya get?) anywhom, water is getting in somewhere and dripping down under the speaker in the left rear of the car (as if you were in driver seat) where is the water getting in? is it through the rear screen seal?
cheers in advance!
boot leak
Bob_S
A1BMW325iSport
sunroof drain?
BigChris
have you got the two door?
Bob_S
sorry yes it's a two door, how do I find out about the sunroof drain? cheers
kidsinister
elliot
have you tried around BOTH rear clusters. my right cluster was leaking bu somehow water ended up in the left side
irish320i
open your sunroof and pour water down the channels at the vback should come out at the bumper if not your drainage pipe chould be of or like mine it could be rusted through
tourer-dan
When I had a 2 door, I replaced both rear lamp gaskets and also the seal around the petrol cap locking mechanism (the bellows-like one) When it still leaked I used a block of wood as protection and gently banged the boot seal flange upwards to create a tighter seal around the bootlid which cured the problem.
Bob_S
it's definately not the gaskits as they are new as I bought some and it's fixed 1 problem. I think it might be the sunroof, will have a mooch in a bit cheers folks!
