My New 320i
Daz87UK
Post Fri Feb 12, 2010 11:12 pm
I figured after 18 325's its time to hit the 320 and check out the difference. On the test drive of this, I immediately knew it had alot of potential. I am blissfully unaware of the mods but will be stripping it to find out very soon... 10pm on Friday night (an hour ago) I finished fitting the well needed new Rotor Arm, Dizzy Cap, HT Leads, Sparkies & Strut Brace (as pictured)
You will be able to see the new oil filter in one of the pics too.
Other mods that came with the car that I 'do' know about are:
Koni Adjustables -40mm
Custom Adapted Mitsubishi GTO Exhaust
Some form of cam (which gives a 3000rpm boost and lumpy idle)
318iS IMMACULATE interior
Coming Next:
Painted Rocker Cover (what colour though? red maybe...?)
Will update as I find out new things or add new things...
After a good clean...
New HT Leads & Manifold Gaskets...
New Dizzy & Rotor... (Obviously the Rotor is hidden)
New Strut Brace...
Old & VERY worn out poop...
tha881
Post Tue May 11, 2010 12:10 am
Hi mate nice car love my 320i also, they are so smooth. Im looking to replace my dizzy, rotor and leads aswell. Just wondered if you used a bosch distributor cap? Also what leads did you buy and how much did it all cost? i would be really grateful if you could help me with the info? thanks in advance :wink:
