M52 wont fire up
bryE30
Post Sun May 09, 2010 10:46 am
Hi ,
I have just wired in a 1995 M52B28 into my 1989 320i , when i tried to start it it turns over well but does not fire up , when i was connectiong my C101 to the X20 there were no wires in pin 14 for either, this should be for the speed sensor right? is this why it is not starting and how can i fix please?
also I read that all the un-used X20 wires should be put to a resistor then to ground, please can anyone give me a bit mor info ?
thanks
Bry
Cook318IS
Post Sun May 09, 2010 10:51 am
you have wired the ews in yeah? The unused cores of x20 i just essentially taped up and tied them into the wiring cover (not quite that crude but it gives you the idea).
Did you use the wiring diagram in the sticky of the engine conversions section? I found that pin 14 on x20 wasnt there either. i made this of the connections i used
it doesnt include the connections for the check control panel because i dont have one of them.
Post Sun May 09, 2010 12:07 pm
have you got the fuel pipes connected the correct way around?
Bob_S
Post Sun May 09, 2010 12:55 pm
it'll be ews :)
Bollocks to this 24v scrap!
bryE30
Post Sun May 09, 2010 11:00 pm
ok , thanks guys, i did not think my engine had EWS so if it has then it is probably that ! it does turn over though, i have tried the fule lines both ways round , and i am pretty sure i had it right the firs time ( fuel pressure regulator on fuel return ) pin 14 is now connected to pin 9
Cook you mentioned wiring the check control panel , i am not sure what you mean? sorry i have only been working on cars for 2 years and this is my first project !!!
how do i wire the EWS then?
Post Mon May 10, 2010 12:08 am
First question is "do you have all the matching EWS bits?" I.E. ECU, EWS module and key from the same car, plus an ignition switch antenna and the receiver/transmitter module.
bryE30
Post Mon May 10, 2010 10:12 pm
i have the ECU and key from the donor car ,i am pretty sure i dont have an EWS module.....where is it on the E36?
is it definately an EWS issue ? the fuel pump activates when the egnition is on as i turned the key with the fuel lines disconnected just to be sure. and there is plenty of fuel coming through !!
bryE30
Post Mon May 10, 2010 10:30 pm
other things it may be are :
power steering not connected up
ABS not connected
secondary throttle not connected
or..........is it possible to bypass the EWS ?
bryE30
Post Sun May 30, 2010 3:25 pm
Ok so of course you guys were right it was EWS , I wired it in and the bugger fired up !
it sounds like a monster as it has no silencer on at the moment,
Thanks for your help anyway guys
