Beemerlad's M52 Chromie
Sun May 02, 2010 9:06 pm
I have neither a bench or a vice mate :)
Sun May 02, 2010 9:30 pm
Nice one bruv :thumb:
Dont forget to pull the rad cowl out :D
**BANNED**
Mon May 03, 2010 2:30 pm
Good to see this coming together!
Looks like you need a bit of Dulux rightness around the top of the slam panel.... winkeye
Youth is wasted on the young.
Mon May 03, 2010 3:40 pm
If this is brake fluid you want to be getting it cleaned off with some solvent before it starts looking like the area under the clutch master cylinder in the engine bay :)
Mon May 03, 2010 8:44 pm
yeah I've given that a quick swill.
Just ordered the 55mm AVO's, hope they ain't too low for the sump :?
Mon May 03, 2010 8:52 pm
They will be fine.. Mine is looooow.. The sump is fine!
stup86
Mon May 03, 2010 9:53 pm
DanThe wrote:Dont forget to pull the rad cowl out :D
Didn't know this was required for a 24v conversion.
Glad I read this now!
Parts needed:
M40/M20 ignition coil with high voltage lead
Mon May 03, 2010 10:20 pm
It is if you want to fit a fan in front of the rad, the cowl is a git to get out once the engine is in
gareth
Mon May 03, 2010 10:52 pm
Jhonno wrote:They will be fine.. Mine is looooow.. The sump is fine!
not sure how low mine is but on almost every road south of scotland it's fine. however 'spirited' driving on some of the more interesting single track sections left my sump/undertray looking like this:
neatly trimmed for perfect underbody aerodynamics :lol:
note to self: raise coilovers before next years roam, they''re there for a reason! :P
town325i
Tue May 04, 2010 9:31 pm
Even my m20 sump took a battering but that is no where near as low as an m50 sump
leeparkes
Tue May 04, 2010 10:08 pm
gareth wrote:Image
You sure thats jacks strong enough Gareth :D
gareth
Tue May 04, 2010 11:38 pm
town325i wrote:Even my m20 sump took a battering but that is no where near as low as an m50 sump
another reason to have a M30 then. :D
leeparkes wrote:
gareth wrote:Image
:lol: well spotted! :D
it's the heaviest 1 ton jack i've ever seen, but it will go under my car (at about 70mm drop maybe?) and lift it to about 450mm in one hit :cool: and will happily jack up a hilux.
i can however only just lift the thing 8O :D
Wed May 05, 2010 9:02 pm
Well the bits are coming together.
M52 manifolds and downpipes arrived yesterday and today the AVO springs arrived - bloody good service from Europerformance as I ordered those online on bank hol monday evening. Also prop centre bearing and mount arrived today.
So I can get the front end back together and then I'll drop the donk in. Got a lad coming to collect the M10 on Sunday and it's sat on the floor in front of the car, so the car has to be rolling by Sunday otherwise the M10 is going nowhere.
Wed May 05, 2010 10:05 pm
You could always roll it on the trolley jack, if need be... :idea:
Wed May 05, 2010 10:09 pm
driveway is a bit crap and turns into gravel near the front so it needs to be on wheels. Gives me incentive to crack on. It's no real drama to fit the springs and bolt up the struts and fit the front arms really is it.
Could do with getting the M3 eccentric bushes pressed into the lolipops off the chromie so all the front end is just done in one hit
Wed May 05, 2010 10:15 pm
Fairy muff; having done this recently on a Minor Traveller's front end, I know where you're coming from, so best of luck with it all :)
Wed May 05, 2010 10:28 pm
M30's and morris travellers 8O
WTF is this thread turning into!
Wed May 05, 2010 10:29 pm
A proper Scout Leader-fest; where's my woggle? :wink:
town325i
Wed May 05, 2010 10:53 pm
Speedtouch wrote:A proper Scout Leader-fest; where's my woggle? :wink:
peedo fest you mean :D
Lee i hope my M50 conversion isnt finished before your chromie is done
Wed May 05, 2010 11:40 pm
I'm aiming for it done by the next bank holiday weekend :twisted:
town325i
Thu May 06, 2010 10:12 am
About the same sort of time as me then :D
Im struggling to get my arse in to gear to take the old engine out :(
Fri May 07, 2010 8:59 pm
Got a wee bit done tonight when I got in from work.
Got the arms bolted upto the subframe, council dynamics ARB back in place, then fitted the new springs to the front struts.
BUT, I have hit a small snag. I have obviously been a bit of an animal when I removed the arms from the touring and smacked the top of the thread on the passenger side outer balljoint. So I can't get the nut to start on the thread.
The threads look pretty fine. now I haven't got a tap & die set, but would one of these usually have a die fine enough to just sort the thread out at the top? If not, what is the solution here boys?
This is the only thing that is stopping me from finishing the front end and getting it sat on the wheels and also dropping the M52 back in.
Also, having a mental moment with the M52 exhaust manifolds (which I haven't yet fitted upto the engine), but does the longer manifold bolt to the front 3 or the back 3 cylinder ports?
I'll curse myself here, but I really do reckon this thing will be about ready for action at the end of the month.
johnl320
Fri May 07, 2010 9:14 pm
Use a thread file or needle file to clean the end of the threads up. We use these a work sometimes. May go fine enough
http://www.drapertools.com/b2c/b2citmds ... kmno=68703
stup86
The manifolds fit this way round:
Hope that helps mate
Parts needed:
Fri May 07, 2010 9:18 pm
Thread file will sort the animaled ball joint
http://www.google.co.uk/product_url?q=h ... cQgwgwADgA
Longer one to the front
Please get some waxoil or at the very least old engine oil on those rusty bits!
Good progress! :D
Fri May 07, 2010 9:27 pm
Nice one, I'll go & get one of those files tomorrow morning, need this bitch back on it's wheels.
Which rusty bits are you on about Dan, I'm not covering the whole car in engine oil :)
Fri May 07, 2010 9:45 pm
Bucket of oil and a big brush :)
Sat May 08, 2010 5:50 pm
She's sat on 4 wheels again now :cool:
Will wait until the lad has been tomorrow and collected the M10 and then get the donk dropped in.
town325i
Sun May 09, 2010 12:12 pm
What you doing about the exhaust lee?
Sun May 09, 2010 2:32 pm
I've got a virgin pair of M52 manifolds and some downpipes, going to see what I can get away with. Dezzy has volunteered to bring the welder through. I plan to mate it upto the 325 2 piece system I was using on the touring. I will probably get away with the rear branch not needing modifying as I have the modified steering UJ setup, so no bell end donut affair to worry about.
Anyway, the engine & box are now in :P
Back end up in the air
Ready for action
In she goes sailor
On the mounts :)
Now it is in, I will have a play with the manifolds and see what fun I'm in for.
Cook318IS
Sun May 09, 2010 2:41 pm
wooot!!! no hanging around as much this time :D nice one! How long do you think it will take you to get it on the road again?
My manfolds didnt need to get chopped to bring them closer to the engine with my uj.
Daf318is
Sun May 09, 2010 2:42 pm
This seems to be going a touch quicker than the touring :D
Good mornings work there by the looks of things :thumb:
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Sun May 09, 2010 2:45 pm
End of the month and I hope she'll be ready for some rent in the screen.
Jobs left are:
1-Get all the wiring etc connected up
2- remove complete rear end and fit touring rear end with LSD etc
3- remove fuel tank & replace with 63ltr one
4- replace front to rear fuel pipes & brake pipes
5- replace prop & fit new centre bearing & mount
6- sort exhaust system
general finishing off jobs etc etc
oldroydsr4
Sun May 09, 2010 6:28 pm
How does it sit on the avos?
Sun May 09, 2010 7:56 pm
oldroydsr4 wrote:How does it sit on the avos?
Honestly can't say yet as I've not had it on the floor properly with the lump fitted. Still got the comedy ride height rear end on. Pushed it back off the drive earlier today when it had no lump in and it had a good bit of rake even without the engine in.
Will be at least next weekend before it is sat properly I reckon.
Anyway, got a little bit more done after getting the lump sat on the mounts.
First of all I fitter a replacement blower motor as the chromie one only worked on speed #4. Then got ECU in place and connected up, connected a lot of the sensors etc on the engine, heater pipes connected, fitted the rad and the electric fan.
Not really happy with how the rad sits compared to in the touring (which used plastic brackets either side of the front panel for it to sit on). This sits a fraction lower and consequently the top bracket doesn't hold it firm so you can wobble it back and forth a little. :?
I'm pleased with where the sump sits though incase it is a little low at the front end.
I've left the comedy 4 pot single horn :)
Went to fit the inlet manifold and I can't for the life of me find the damn nuts that hold it on, so it is just in place at the mo. That's where I ended up.
Despite no spare engines laying about and some other bits now on the car, the garage is still an utter shithole :D
