Hi All,
I have a lightweight flywheel for my M20. What is the easiest way to fit it?
Can i undo the prop at the box and drop it, then undo the box and shift it backwards to get access to the flywheel?
Any help appreciated
Flywheel fitting
- **BANNED**
Good chance to fit a new clutch whilst it's all in bits.....
Youth is wasted on the young.
A standard 325 spec LUK or SACHS will be fine unless your running a big turbo, I'm using an LUK in mine with no problems... Except the time I planned to do a smoky start and put it in 3rd by mistake, the clutch wasn't keen on that
In retrospect I think the SACHS is the better clutch, it's what BMW fit at the factory.
(200 bhp / 185 Lb:Ft 2.8 engine)
