My new toy - E30 M3 - Wheels on.
mabz
looks perfect dude big improvement with the wheels even tough there a cnut to clean there well worth it
Rich_W
Que? I would guess like most M3's it's already got themJhonno wrote: Needs some eccentric front bushes though
Kieran, needs some spacers
- Homo Hair
Doesn't look like it does in the pics.. Look like it sits too far backRich_W wrote:Que? I would guess like most M3's it's already got themJhonno wrote: Needs some eccentric front bushes though![]()
Kieran, needs some spacersLooks good though, I did a double take though at first as I took a pic like that years ago!
Bob_S
They are there alright.. It needs proper M3 springs on it to look right it still looks too low imo..
Bollocks to this 24v scrap!
kieran325
I've tried to get genuine BMW springs, Germany have the rears but have no fronts and will not be producing anymore until a big order comes inBob_S wrote:They are there alright.. It needs proper M3 springs on it to look right it still looks too low imo..
I'm gonna give the front spring pads a whirl
Deffo looks like it needs the off set control arm bushes.
The spring you need is shared with other models with M tech suspension.
http://www.realoem.com/bmw/partxref.do? ... showeur=on
Rich_W
I'm probably being thick.
Kierans
Mine
Now bearing in mind this pic of my car is on the original (knackered at the time) suspension and it does have offset bushes. I can't really see that much difference
Sure the front wheel maybe sits marginally further foward in the arch than on Kierans, but I'm not sure why the offset bushes would have that effect?
Kierans
Mine
harry_p
rich, the idea of offset bushes is to push the mount under the footwell towards the sills, and as the lower arm is an L shape it will twist on the subframe balljoint and push the end of the arm the wheel is attached to forwards in the arch, and increase castor.
mine has offset bushes, but the wheels still sit slightly rearwards in the arch, i have just assumed that whoever set them up just set them to the factory settings, which when combined with lower springs makes the wheel sit back a bit.
i think youre looks pretty much spot on now kieran, front pads wont make anywhere near as much difference as the rears because of where the spring is mounted. do you know what springs it's on? it sits very similar to mine on eibachs, personally i could never go back to standard rideheight, which is just a bit too rally car for my liking
cheers,
harry
harry
Rich_W
Harry.
Cheers. Does it actually affect anything you can feel though? More Castor mean more stability I suppose. But we aren't F1 drivers, so can we really tell 25mm? On our crappy road surfaces?
harry_p
Castor also affects camber when turning without altering static camber. The easies way to think about castor is by pulling the strut top mounts toward the bulkhead, the strut will lean back so when you turn the wheel and twist the strut the wheel will lean over as well as turn.
On a track car it's great because you get more negative camber on the loaded up outside wheel as you turn, without having to run silly amounts of normal camber which reduces stability and braking.
On a mainly road car the standard settings are fine. M3s already run more castor than standard e30s
cheers,
harry
harry
