lower door mouldings on cab
dobbey1
does anyone know if all cabriolets come with door moulding trims just below the doors . these trims sit just above the seals and run the full length of the car from arch to arch. and do these have to be removed when fitting an AV3 bodykit side skirt so that the skirt would then sit just below the door cheers all help welcome
Sooty
Are these the trim mouldings with the three grooves running along the full length of them?
If so, they are the MTech 1 bodykit sideskirts.
They were an optional extra on the original car and yes, you will have to remove them if you want to go with the AV3 kit.
If you DO go with the AV3, I know a man that is looking for a set of the MTech sideskirts.
Iain S
Iain S
dobbey1
sorry mate these mouldings are just the standard moulding that sits between the door and the seal
jordano
im looking for the passenger sidedoor moulding that you speak of if you are getting rid. Think they are standard on the cab as there on my mums as well
