From the states: After a year of searching, Alpineweiß II
iwantspeed
Post Fri Apr 09, 2010 12:23 am
Hey guys.
I purchased a 1987 325e
I did some minor work to it and I have been daily driving it for the last 2 years.
Ever since then I wanted another e30.
I have found a few for sale here on r3v, e30tech, ebay, autotrader, craigslist, bimmerforums. Through local advertisement in papers and automotive catalogs.
I'm a bmwcca member and have check the classified section of the roundel for an e30.
I have purchased one way plane tickets to cars that I thought were the one for sure. With something always coming up.
Yes I'm picky, but its my money an I wanted a nice example of a clean e30.
I ended up finding one right in the city I live in.
I was on my way home when I saw an alpinewhite e30 driving on the same street in the opposite direction.
I immediately made a u turn to go check out when I hit a red light.
As soon as it turned green I floored it to try to catch up to it.
I saw the e30 turn into an automotive complex of shops.
I parked next to the e30 and then went out to find the owner.
I met the owner and asked him if he was interested in selling the car.
He politely told me no not at the moment and left in another car.
He was dropping off the car at a shop to get his fuel filter and some other maintenance done.
I talked to the mechanic and he put it on the lift for me. I took detailed notes and several pictures of the car.
I also found out that the this mechanic (eric) has worked on this car for the last 7 years. So he knew a thing or two about the car :pimp:
I left my name and number with the mechanic to attach to the invoice just in case the owner decided to change his mind and sell me the car.
I wrote down the vin and license plate to do some hw and research when I got home that night.
I found that the car was indeed a alpinweib II car with no airbag. Build date 12/14/1988 BMW only made these for approximate 8 months with a clear coat but no airbag.
It was the reason why I had such a hard time finding an e30.
It was well worth the wait.
I also ran the carfax and the car has only been registered in southern California its whole life and shows no accident damage.
About a month after finding it the day at the shop I got a call from the owner and he said that he was ready to sell.
Immediately went over to negotiate the car with him
we came to an agreement and I asked him to go with me to the dmv to get the title transferred I wanted to do it in person.
Just for personal reason's I didn't want something to come up later on.
Got the title all squared away got the car insured and went off for a drive down to San Diego.
The day I found her at the shop.
Up on the lift for inspection.
Yes the blue bmw was out of the way when I inspected her.
When I snapped the shot it was closing time at the shop and the were storing the blue car underneath.
The day I bought it.
12/23/2009
I drove down to San Diego to open her up on the highway:pimp:
Getting some 91 octane at Chevron
Got her home and assessed the condition she was in.
engine bay
hot air filter
cracked intake boot
cracked idle control valve hose
cracked valve cover to throttle body hose
misc wires unplugged and in a mess
overall pretty dirty
misc wiring in the battery tray
valve cover gasket leaking on to heat shields
checked out the interior in close detail
Cracked dash
sony headunit
misc led's above headunit
4 spoke steering wheel
old shifter
sloppy shift linkage
torn shift boot
fluctuating gas gauge.
missing rear center console
missing rear ash tray
cracked ebrake handle
stains in the carpet
non oem matts
sticky passenger seat belt buckle
sharpie mark in the rear seat back.
So I started off with the engine bay.
I wanted to get rid of the filter setup.
The engine ground strap was in sorry shape:(
corroded and just looked terrible.
Yep sure was time to replace
I had to special order one at the dealer.
3 days later I got this badboy
Much better
I wanted to check if my cps was in spec.
And although it was I replaced it anyway as the cable was frayed near where it crosses the front of the motor.
I replaced the throttle body gasket, and I also cleaned the inner part of the throttle body gasket and the inner part on the motor side of throttle body.
I replace the idle control valve hose, the valve cover to throttle body hose
and the intake boot cleaned the afm a bit and acquired a used afm from Peerless at e30 motorwerks.
It came with an old filter so that was immediately replaced with a stock mahle filter
Installed an upper radiator hose and zip tied out of the way to prevent it getting caught in the clutch fan.
and here is the before shot of the cap, rotor and wires
old vs new rotor
old vs new cap
I haven't decided which spark plug wires to get here is a thread on that.
But I'm leaning towards stock
http://www.r3vlimited.com/board/showthread.php?t=164076
I wanted to figure out what the extra wires that were in the battery tray were for.
I traced them back and went from the battery tray across the firewall zip tied to the stock wiring harness and it went into a plug in the firewall near the brake booster.
I removed the lower dash panel, to see where the wire leads were going to and the wire was cut right there.
It was fed through the firewall and just cut there.
I believe the car has an alarm installed by a past owner and the previous owner just cut it out.
extra wiring in the battery tray
wiring across the firewall
wiring at the firewall plug
wiring removed
Engine all buttoned up, for now...
Now that the engine was all buttoned up I went to my smog guy.
In the state of ca you have to have an airbox or you "can technically" fail visual inspection. Some smog guys don't really care but I wasn't going to risk it.
O did I mention my smog guy used to track a zinno e30 with a full cage and used to track an e36m3
now he is tracking a delphin gray shade of gray e36m3, you can see it in the back left of the shop.
This is the only other person who has driven my e30 since I bought it and Im half way comfortable with it because he used to have an e30 and he has an e36 m3 now.
Super Smog in Lake Forest Ca.
Ask for Danny
track prepped e30 & e36
getting tested for nox and co2
his m in the back corner
The car passed the dreadful CA smog with flying colors!:pimp:
shot to celebrate passing smog first try.
325I
Alpinweib II no airbag
5 speed
iwantspeed
Next, It was time to address the interior
First up, was to replace the led's
When I removed them they weren't even connected to anything:confused:
I think that they might have had to do something with the misc alarm wiring that I removed.
Yes I know my obc is fubared:hitler:
im trying to source a 13 button obc, wiring harness and turn signal stalk.
with the blanks
Next up was the dash.
I used this guide to replace the dash
http://home.comcast.net/~cdeegan9/dashb ... ard_1.html
getting there.
dash out
Crummy duct seal
Scrapped it with a razor blade and a small flat head screw driver to get the old gasket material off.
I had a hard time finding the gasket but I made a thread about it and Drew325is found the part number I needed.
http://www.r3vlimited.com/board/showthread.php?t=158804
Installed and it fits like a glove.
I love it when things just go right.
Either the previous owner or a shop that it was taken to did a hack job on installing the sony headunit.
I fixed the mickey mouse job and also eliminated the factory fader and ran new wiring to the driver side corner where the speaker wires are fed to go to the rear of the car.
I also made a plug so i can just plug in the factory antenna once the dash is back in and not have to solder or crimp any fittings later on.
I soldered everything and heat shrink tubing on all the joints and had wire mesh to bundle up the wiring. I prefer this setup over crimping connections.
Previous owner hack job
All tidied up except for the alpine direct cable.
I went with a Alpine 9881 unit.
It had the features I wanted
cd mp3 radio
3 rca's
i pod direct control on the head unit
detachable face plate
and the best part is that the buttons light up amber.
I got rid of the 4 spoke steering wheel
I went with an M-Tech 1 wheel
I got rid of the ugly tan speaker covers and added mint condition black ones, pics coming soon.
I had a company that steam cleans carpets come out to my house. I removed the seats and left the center consoles out and had them remove all the stains. They also did the matts that I just got.
Bavarian Autosport matts.
Dirty carpet driver side
Dirty carpet passenger side
Coffee stain, Thanks previous owner.:mad:
Do work:o
Driver side done
Passenger Side done
ZHP 5 speed cut and weighted shift knob total weight 5.5 ounces
From bimmerforums, TischerBmw
http://forums.bimmerforums.com/forum/sh ... p?t=746293
I bought this e34 early model(1990) emergency brake handle
I bought off of Schneller 3er, he was a very good seller and quick shipper
Z3 1.9 shift lever, thanks Sean at Irvine BMW
old vs new
I added an early model center console with 2 buttons and no hole for the breaker switch.
I have the breaker switch wired in underneath and still functions the same,
I also added an extra breaker switch to function as a garage door opener. and the garage door opener is mounted above the ecu.
2nd breaker
Ya i know its upside down I didn't realize till later:loco:
2 hole center console
stock shift knob, stock shift lever, stock shift boot,
stock shift knob height. 5 3/4
bend the selector shaft
installed the zhp knob
Z3 1.9 shift lever
bav auto shifter boot with trim ring removed & an inch removed from the top to clear the shift lever.
Final height is a shade under 5 inches.
I installed mint condition front and rear seats
I also purchased a Bav Auto dash cover to protect the mint dash
I also Purchased Bav autosport plush black matts
I replaced the sticky seat belt buckle that eventually just fell apart with a good working one.
stock trunk tool kit and one trunk light
7 series trunk tool kit
swap tools over
installed
showing off
I need more tools
and purchase a larger foam pad, I think Japanandrew can hook it up.
I have a 2nd trunk light I just haven't wired it in yet.
325I
5 speed
iwantspeed
Post Fri Apr 09, 2010 12:24 am
The previous owner has tried to do all red tails mods.
I like the look of this but the paint had faded so it had to go.
I sanded both turn signals until the amber showed up and then polished up.
I'm not entirely happy with results but it will do for now.
I got a new month and year sticker, so I stripped off all the old year stickers
and new stickers
new front license plate bracket,
new hardware for the front and rear license plates.
325I
5 speed
iwantspeed
I took apart the ecu
and I added a Jim Conforti chip
raised the rev limit
91 octane
and a small increase in hp and torque
close up
I took apart the cluster
I replaced all the bulbs and the odometer gear.
bulb housings all bubbled up
new bulb housings
all new bulbs and new odometer gears
325I
5 speed
iwantspeed
Meet Natalie
details
1989 325I
Alpineweiß II
Tan Natur vinyl comfort seats
5 speed
120k miles
engine
m20b25
removed ac
removed power steering
fresh air filter
fresh synthetic oil
new timing belt,tensioner
new water pump
rebuilt head
new cap
new rotor
various vacuum hoses
various radiator hoses
new crank position sensor
Jim Conforti chip
new hood seal
Bosch Platinum plus plugs (gaped at 0.03)
Int
crack free dash
rebuilt cluster
early model center console (2 button vs 3 button)
M-Tech 1 wheel large diameter
e30 m3 ebrake boot
e34 ebrake handle
e46 zhp 5 speed shift knob
bav auto shift boot
extra window breaker for a hidden garage door opener.
bmwcca sticker on driver 1/4 panel on the happich window :)
Bav autosport matts
7 series large tool kit
stripped trunk( no sound deadening)
2nd trunk light(to be installed)
e30 specific sun-shade
bav auto dash cover to protect it from the sun while parked
Sound Improvement
alpine 9881 headunit
alpine i pod cable
Eliminated speaker fader
Ran new wiring to the speakers
i pod nano hidden in center console
Premium sound tweeters(not installed)
pioneer rear speakers
stock speakers in the front for now
swapped the tan speaker covers for black ones
suspension
H&R Touring Sport Cup Kit
21mm front Convertible sway bar (to be installed)
Rongineer rear strut bar (to be installed)
new rear trailing arm bushings
new rear subframe bushings
10mm rear spring pads
Brakes
Ate rotors(not installed yet)
Ate pads(not installed yet)
6x Bimmer world stainless kevlar lines(not installed yet)
Ate super blue DOT 4 brake fluid(not flushed yet)
Trans
new clutch master cylinder (not installed yet)
slave master cylinder(not installed yet)
UUC stainless kevlar clutch line(not installed yet)
new bmw clutch master cylinder to reservoir line(not installed yet)
z3 1.9 shift lever
stock rebuilt shifter bushings
3.73 open diff
wheels and tires
17x7.5 Kopi Alpina's
4 lug casting
Continental Extreme Contact tires
215/45/r17
No spacers
slightly rolled rear fenders
325I
5 speed
pukar
Post Fri Apr 09, 2010 12:45 am
wow!!! you dont do things by half do you?
nice to see you take real pride in your work, and the finished product is testamant to that......looks real nice buddy! :cool:
kieran325
Post Fri Apr 09, 2010 8:56 am
Well done 8)
suchy
True Zone Relic
Post Fri Apr 09, 2010 9:55 am
Blimey I just thought at first it was going to be a "I just bought this....and I've just washed it"
Slightly more went into that!!
Nice ride 8)
Post Fri Apr 09, 2010 10:33 am
Welcome, and an really good write up :cool:
iwantspeed
Post Fri Apr 09, 2010 11:54 pm
Thanks guys
new picture
I would like
euro grills
smiley's
oil cooler trim piece
paint matched is lip
alpineweib II mirrors
325I
5 speed
tonybtonyb
Post Sat Apr 10, 2010 1:49 am
looking nice :cool:
Post Sat Apr 10, 2010 2:39 am
excellent work and a nice clean car 8)
bobbin1982
Post Sat Apr 10, 2010 9:45 am
Lovely car mate...you must have spent some pennies on it already with all the new genuine BMW parts
Andy
Driving my digger!!!!
Alpina99
Post Sat Apr 10, 2010 10:11 am
That car looks really good, clearly something to take pride in when you're driving around,
(Looks a nice place to live as well !!)
:D :D
Gone, but not forgotten !!
Post Sat Apr 10, 2010 4:02 pm
Looks lovely, just needs a set of sports seats, not a fan of the US spec Vynal seats. It seems a popular colour combo over in the states white and Cream, looks nice too
iwantspeed
Post Sat Apr 10, 2010 8:12 pm
pukar wrote:wow!!! you dont do things by half do you?
if you are going to do things half assed why start in the first place.
Thanks man.
kieran325 wrote:Well done 8)
Thanks man
suchy wrote:Blimey I just thought at first it was going to be a "I just bought this....and I've just washed it"
Nice ride 8)
The first thing I did when I bought it was a drive down to san diego ca.
Rav335uk wrote:Welcome, and an really good write up :cool:
Thanks mate
tonybtonyb wrote:looking nice :cool:
Thanks man
magpie wrote:excellent work and a nice clean car 8)
Thanks sir
bobbin1982 wrote:Lovely car mate...you must have spent some pennies on it already with all the new genuine BMW parts
Andy
Yep got to get the good stuff.
And yes it adds up.
Alpina99 wrote:That car looks really good, clearly something to take pride in when you're driving around,
:D :D
Yep I love taking her for drives.
The beach you see in the background is one of my favorite beaches.
Alex wrote:Looks lovely, just needs a set of sports seats, not a fan of the US spec Vynal seats. It seems a popular colour combo over in the states white and Cream, looks nice too
I’m not fan of vinyl economy seats either. These are better then what where in there before.
Long term goal
The front is getting e30m3 leather sport seats with heating pads horizontal stitching and in black leather
The rear seat is getting an e30 m3 2 person bucket seat also in black leather . And relocating the rear seat belt buckles
They are hard to find and even harder to find in mint condition. They are also super expensive.
325I
5 speed
makanicO
Post Sun Apr 11, 2010 4:40 am
Nice :)
Z3I
Post Sun Apr 11, 2010 6:21 am
Superb write-up, great pics, you've set a new standard!
I quite like the white with cream too..
pac1982
Post Sun Apr 11, 2010 7:55 am
Some great work there and a great E30, one thng though it looks like your missing the mtec colours on your Tech 1 wheel
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Japandrew73
Post Sun Apr 11, 2010 9:42 am
Looking great Alex! Your comfort seats are so clean but I love your plan of M3 front and rear seats. That's always something I've wanted to do... except with recaro front! :twisted:
And if you're ever curious about how to complete your e34 toolkit, this is what my Dad's kit I completed for his Christmas gift looks like...
iwantspeed
Post Mon Apr 12, 2010 6:58 am
makanicO wrote:Nice :)
Z3I wrote:Superb write-up, great pics, you've set a new standard!
I just wanted to share my progress.
I’ll enjoy the cream interior for a while until I source some black interior.
pac1982 wrote:Some great work there and a great E30, one thng though it looks like your missing the mtec colours on your Tech 1 wheel
I love the shot of your car in your avatar.
I want some smiley low beams
Euro grills
And an is lip.
You are right sir I am missing my mtech badge on my mtech 1 wheel.
I will pick one up at the dealer.
Japandrew73 wrote:Looking great Alex! Your comfort seats are so clean but I love your plan of M3 front and rear seats. That's always something I've wanted to do... except with recaro front! :twisted:
Thanks Andrew.
I’m set one the m3 interior, I just have had a hard time sourcing one.
I was curious on what I had left to collect for the tool box.
325I
5 speed
iwantspeed
Post Mon Apr 12, 2010 7:14 pm
I ordered some Bosch platinum plus spark plugs.
I also special ordered a e30 specific sunshade from Irvine BMW ( Thanks Sean and Alex)
Currently a 20% discount on accessories
I couldn't combine my BMWCCA discount to get an additional 10% off but 20% is still good.
Just print the coupon, Limited time only
http://www.irvinebmw.net/specials/parts/
New plugs and anti-seize
Old vs New.
I was also happy to find that the previous owner had a set of bosch plugs too.
New sunshade, I picked it up from the dealer on Monday
Safe spot at school
furthest spot possible
You can't park in front or on the left side.
You can only park next to it one side.
Parked all the way towards the driver side.
Mirrors folded in.
sunshade up as well as the dash cover.
Culdesac shot in a private neighbor hood in south Laguna Beach.
We Convinced the security guard to let us in the neighborhood to take pictures.
325I
5 speed
schnaarf
Post Mon Apr 12, 2010 9:09 pm
It looks good - nice work. Like the E34 tool box too.
Duke137
Post Tue Apr 13, 2010 12:15 pm
Awesome
iwantspeed
Post Tue Apr 13, 2010 9:41 pm
schnaarf wrote:It looks good - nice work. Like the E34 tool box too.
thanks
mine is from a 7 series
Duke137 wrote:Awesome
thanks man
325I
5 speed
Post Tue Apr 13, 2010 10:26 pm
Some hard work has gone into that and the results show.
I've got to ask though, why remove the A/C especially in Cali?
Royalratch
Post Tue Apr 13, 2010 10:37 pm
Detail detail detail!
Awesome work - nice car. Maybe try some tyres that are a little closer to E30 period?
S'all good.
Post Tue Apr 13, 2010 10:46 pm
love it !
e30 ownership without the rust ! that is turning out to be a great car :D
iwantspeed
Post Wed Apr 14, 2010 5:36 am
bss325i wrote:Some hard work has gone into that and the results show.
Thanks mate
You should direct that question to the previous owner.
I purchased the car like that and I used it to lower the purchase price but in reality I didn’t mind to much.
I rarely use the a/c
And less load on the engine is a plus.
I also like how much cleaner the engine bay looks without the extra components for a/c
Those who don’t have a/c want it. Those who have it don’t appreciate it.
Royalratch wrote:Detail detail detail!
S'all good.
Thanks man
I would love to have an authentic set of staggered 16inch alpina’s
I would also like to have 15inch kosei k1 wheels for autocross duty.
But not really a priority right now.
e30topless wrote:love it !
thanks I own two e30’s
the one in this thread
1989 325i
And a
1987 325e
Both have no rust.
I love buying Southern California cars
325I
5 speed
iwantspeed
Post Wed Apr 14, 2010 7:42 pm
First car show with Natalie
Car and Coffee in Irvine Ca.
I met Paul Cain the owner of a beautiful 2002 that was just published in Performance BMW.
Parked next to an e30 m3 of course
325I
5 speed
Royalratch
Post Wed Apr 14, 2010 7:45 pm
If only you knew the bother we go through to find and keep cars rust free.
You probably wade through them...
iwantspeed
Post Thu Apr 15, 2010 11:10 pm
Royalratch wrote:If only you knew the bother we go through to find and keep cars rust free.
Ya that would totaly suck.
I would still try to fix the rust little by little.
325I
5 speed
iwantspeed
Post Thu Apr 15, 2010 11:11 pm
bimmer_E30 wrote:beautiful car, pretty much my dream e30 rightthere, late model, plastic bumper, alpina and "i"!
thanks man
Irvine CA
One of the photographers from Cars and Coffee took a shot of my car at the entrance.
Sat 03 Apr 2010 06:58:30 AM
f/8
1/160 sec
Canon EOS DIGITAL REBEL XT
325I
5 speed
m_jermyn
Post Fri Apr 16, 2010 12:25 am
I always say it better to pay a little more for a car and do a little less work rather then pay a little less for a car and do a lot more work..
This is what I call inspirational a very impressive E30 and they look so good in white (has to be the best colour)
Only thing to do now is sort out that lip spoiler and she is done..
Mike
iwantspeed
Post Fri Apr 16, 2010 12:36 am
m_jermyn wrote:I always say it better to pay a little more for a car and do a little less work rather then pay a little less for a car and do a lot more work..
Mike
thanks mate
My other e30 isn't quite the looker but fun to drive too!
I agree with your quote.
Plan is just getting an is lip.
Just focused on maintenace > asthetics.
it will come soon enough.
325I
5 speed
