can u fit pop our rear windows to a car with solid rear wind
333i
Sat Apr 10, 2010 10:40 pm
as per title thanks
Sat Apr 10, 2010 10:41 pm
yes :D
333i
Sat Apr 10, 2010 10:43 pm
ok next question how ?
i have bought some rear pop outs but its on the glass bit and brackets what else do i need and how do u do it
dano0
Sat Apr 10, 2010 10:50 pm
dont do it keep the car original
Falkster
Sat Apr 10, 2010 10:51 pm
dano0 wrote:dont do it keep the car original
Why?
Sat Apr 10, 2010 10:54 pm
remove the fixed window, there are 2, 8mm bolts behind the front seat belt, one is behind a round cap, the other is behind the hook thingy at the top of the pillar
the pop out has it's own rubber seal which is obvious to fit in place of the fixed window rubber then the pop out fixes back in place using the 2 nuts which you removed from the fixed window,
that bit is the 'hinge'
next you will need to fit the opener/handle this uses 2 body nuts which fit behind the headling on the back pillar 'you need to pull back the 'lining' to get them in place then fit the 2 screws
hope this helps !
333i
i cant seem to find a standerd rear window tho need a n/s/r one if n e one has one
dano0
Sat Apr 10, 2010 11:03 pm
Why?
i just think it would be worth keeping original
Put it in the "Wanted" section, sure plenty of peeps on here have some somewhere :roll:
mash
Sat Apr 10, 2010 11:04 pm
snakebrain
Sun Apr 11, 2010 2:51 am
It's not a propitious beginning for that car if pop-out windows is the first thing on your mind...
333i
Sun Apr 11, 2010 9:38 am
snakebrain wrote:It's not a propitious beginning for that car if pop-out windows is the first thing on your mind...
why ? urely replacing a smashed window is first on the agenda
