engine still turns over, do you think its the belt ?
snapped timing belt??
m-dtech
- Unapproved Trader caution
Pulled away from a junction in the 518i M40 engine and it cut out.
karlp
If it was the belt snapped you will probably hear the most horrendous noise from the engine (metal to metal).
But I thought the 318/518 engines had a chain.
karl
karl
Gwynleym10
m40's have belt
m10s have chain
m10s have chain
Jimbob
Have a look and see if the belt is snapped? You're missing 2 cylinders so there's plenty of room
tomstickland
Belt snapping usually involves some very obvious damage noises.
m-dtech
car is sitting on a wide road in the layby. not even gone to check it.
cant be arsed.
its a heap of shite.
cant be arsed.
Often on a m40 engined car you can get lucky , its worth sticking a belt on it and trying it , or maybe it ain't ............
SVBMW
Take the oil filler cap off and pull the engine over by hand.
Look in the oil filler hole, and if the cam goes round then the belt in't snapped!
