stolen E34
Post Fri Apr 02, 2010 4:35 pm
I did it. !!!!!
Ive nicked my sons 525 e34 but the headlamps are cracked and need replacing. I have some more complete units and I was wondering whats involved in changing them.
Any advice will be most welcome . :D
snakebrain
Post Fri Apr 02, 2010 5:38 pm
Go here, download the manual, have fun!
http://www.bimmerwerkz.com/forum/5-seri ... 42558.html
E34-520iSE
Post Fri Apr 02, 2010 5:44 pm
The Bentley manual is really helpful, that's a good link too snakebrain - I've bookmarked it now thanks! Martauto, did you check out the reply I sent you on the 5 forum?
Cheers,
Shaun M
1990 E34 with M50B25 and T04E turbo & KDFI ECU
1993 E34 525 SPORT
Post Fri Apr 02, 2010 5:48 pm
snakebrain wrote:Go here, download the manual, have fun!
On its way now mate.
Cheers.
Post Fri Apr 02, 2010 5:49 pm
E34-520iSE wrote:The Bentley manual is really helpful, that's a good link too snakebrain - I've bookmarked it now thanks! Martauto, did you check out the reply I sent you on the 5 forum?
Cheers,
Shaun M
I have now Shaun mate and thanks alot for the replies guys winkeye winkeye
320ise
Post Fri Apr 02, 2010 7:06 pm
you have to take the full grille and under lip off to get at them and the hard bit imo is getting at the screw for the indicator lense you'll prob have to take the airbox out and other things to get access at them. not a bad job but more to do than what i thought when i changed my passenger side one (some little twat shot it with an air rifle!)
E34 ///M5 THE BEST BMW EVER BUILT?
toecutter666
Post Fri Apr 02, 2010 7:17 pm
If any of you need any parts from a manual e34 525 tourer, i've just raped one of its engine, loom and other conversion bits, the rest is going on the scrappys lorry to get it off my drive so be quick, just want a drink for anything.
Darren
E34-520iSE
Post Fri Apr 02, 2010 7:25 pm
Hi Darren. Was it a 'facelift' model? I'm after some facelift chrome kidney rings like....
Cheers,
Shaun M
1993 E34 525 SPORT
toecutter666
Post Fri Apr 02, 2010 7:34 pm
Its a K reg mate, no idea if its face lift or not. Got a couple photos if that helps.ImageImage
E34-520iSE
Post Fri Apr 02, 2010 7:37 pm
ah bummer I can't quite make out the front grille from first pic! you got a picture of the front end? Oh I could use that black gear lever surround too if you don't need it! Have you got a pic of the empty engine bay at all?
Many thanks,
Shaun M
1993 E34 525 SPORT
toecutter666
Post Fri Apr 02, 2010 7:44 pm
I'll get a photo tomorrow morning and pm you
Darren
E34-520iSE
Post Fri Apr 02, 2010 7:48 pm
Thanks very much Darren - I appreciate it. Sorry I edited my message but I realised too late that a K plater would have a standard front end, I think I was having a blonde moment!
Cheers,
Shaun M
1993 E34 525 SPORT
Post Fri Apr 02, 2010 9:19 pm
If replacing E34 headlights the move that will save you lots of language is to remove the front bumper, the nuts are behind the black trim. You should then be able to carefully prise the grille panel off without turning the air blue ! :)
320ise
Post Sat Apr 03, 2010 12:31 am
^ good tip! ill do that next time as the bumpers do come off in seconds!
