24 valve conversion gearbox / prop question
GT-UK
Tue Mar 30, 2010 8:28 pm
hello chaps
bit of help needed, currently working on a 24 valve conversion,
im using a e34 m50 2.5,
car has manual gearbox
can i keep the existing gearbox that comes with the m50 engine ?
ie: e34 engine and box in my e30 ??
if i can use e34 box what prop shaft and diff can be used to be the correct length and fitment ?
have engine mounts all in place, just waiting on this info before i plonk the engine in...
many thanks in advance
changes on a weekley basis
bimanut
Tue Mar 30, 2010 8:40 pm
Have a look in the M50 section you should find some answers to your questions and possibly more.
GT-UK
Tue Mar 30, 2010 9:28 pm
cant seem to find the answer to this question on there
town325i
Tue Mar 30, 2010 11:06 pm
An e36 prop with E30 centre bearing is what you need but you will need to find a diff with a better ratio than the one in an e30 as 5th gear is overdrive in an e30 and 5th in the e34 box is 1:1 unless its a really early m50 box and it could be an overdrive box.
GT-UK
Wed Mar 31, 2010 9:09 pm
cheers man
what e36 prop ?
im presuming any m50/2 engined e36 ??
bimanut
Wed Mar 31, 2010 9:21 pm
Not 100% but i think you need a 328 prop.
Cant remember and couldnt find the info.
