E30 IX running gear ??? Anyone tried converting to 4x4?
Ive been bored frankly so was looking into how doable swapping the IX running gear into a 2dr e30 would be??
Anyone tried? whats involved and do u have pix???
More of a chat topic really... oh well...
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
Grrrmachine
- E30 Zone Wiki / Team Member
Don't think it's a straight swap. Running gear includes front legs, steering rack, oil sump, as well as the usual gearbox/diff/prop/driveshaft issues. There MIGHT also be some actual body differences, but I can't remember.
I looked into all this a year back, as my car has the paperwork of a 325iX despite being a 320i mechanically. Good old dodgy imports ;)
Happy days
Might just look for a tatty ix to do up, probably cheaper too... I know u need a short engine if its to be attempted, and legs with shafts etc, 2 props i think
oh well i can dream
oh well i can dream
Sump Baffles
TrackDays
Sump Baffles
TrackDays
Grrrmachine
Yeah, did a search for my old thread. Chassis is different, especially front turrets. Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
Quattro ist fur sissies, anyway
As said the front turrets are slightly differant and the transmission tunnel is wider on an iX. I have all the running gear spare if you fancy a project
The front driveshafts fully pass through the hubs with a large nut on the front just like rear E30 shafts do so I dont know how they modify themGrrrmachine wrote:Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
Theoretically then
what would need to be done to a standard 2 door e30 in terms of squeezing all the extras in? Lump hammer to the tranny tunnel Im guessing? And locate a short engine. And I doubt it would work with my m52
. German eBay me thinks
Sump Baffles
TrackDays
Sump Baffles
TrackDays
The transmission tunnel would need more than a beating I fear !turk wrote:Theoretically thenwhat would need to be done to a standard 2 door e30 in terms of squeezing all the extras in? Lump hammer to the tranny tunnel Im guessing? And locate a short engine. And I doubt it would work with my m52
You would need a sump and oil pick up from an E34 525iX to use the M52 donk
As dips says the M20 block is different underneath for the oil pick up & pump to a normal M20 block, I also have one of these here
Lets talk munneytomson wrote:As said the front turrets are slightly differant and the transmission tunnel is wider on an iX. I have all the running gear spare if you fancy a project![]()
Sump Baffles
TrackDays
Sump Baffles
TrackDays
Depends if you want a switchable auto or manual iX gearboxturk wrote:Lets talk munneytomson wrote:As said the front turrets are slightly differant and the transmission tunnel is wider on an iX. I have all the running gear spare if you fancy a project![]()
PM me if your serious
handpaper
The weak point as I recall is the driveshaft where it enters the front diff. Tends to strip its splines.Grrrmachine wrote:Yeah, did a search for my old thread. Chassis is different, especially front turrets. Plus, the 4x4 running gear has fragilities - the yanks do all sorts of mods to the drive shafts to make them penetrate the hubs deeper.
- StevenC3828
handpaper / guys do you mean the where propshaft enters the transferbox?handpaper wrote: The weak point as I recall is the driveshaft where it enters the front diff. Tends to strip its splines.
Moonlite motorwerks do a spacer for the front prop shaft http://www.moonlitemotorwerks.com/driveshaft
I didn't think you had any ?
