just another m30 swap
gcs325i
Post Sat Mar 27, 2010 9:14 am
Read your thread Lee, what needed modified with the bar and hammer to create the room for the rad?
leeparkes
Post Sat Mar 27, 2010 10:01 am
gcs325i wrote:Read your thread Lee, what needed modified with the bar and hammer to create the room for the rad?
To get the E28 rad to fit?
The rad supports welded to the shell need to go so the E28 rad will slide down between the chassis rails
They are hard to get to with the engine in,i only removed the one on the passenger side and after failing with the grinder, hacksaw, etc... i smashed it down with a solid bar :D
Dont forget you will need a longer bottom hose or modify one like i did
You can see in that pic the drivers side support still there
shedrool83
Post Sat Mar 27, 2010 10:11 am
Thanks Lee
I didnt know the supports had to go and thats were the confusion has come from.
Looks like i'll be using the bar/hammer method to :D
zaust
Zone day release
Post Sat Mar 27, 2010 10:27 am
I used the e28 lower pipe. Fit's like it was ment to be there anyway. The top hose I uesd is a cut down(rad end) E34 one.
M30 Tech 1 Touring on gas.
gareth
Post Sat Mar 27, 2010 11:07 am
zaust wrote:I used the e28 lower pipe. Fit's like it was ment to be there anyway. The top hose I uesd is a cut down(rad end) E34 one.
same here.
my lower rad mounts received a hacksaw and some brutality to shift them! :twisted:
the lower rad mounts i have fitted now are.... tye wraps! :cool:
leeparkes
Post Sat Mar 27, 2010 11:19 am
gareth wrote:the lower rad mounts i have fitted now are.... tye wraps! :cool:
So have i, cable ties FTW 8)
Post Sat Mar 27, 2010 3:08 pm
Bodger!!!!!! :mad:
zaust
Zone day release
Post Sat Mar 27, 2010 4:49 pm
I have too, Great big one's....
shedrool83
Post Sat Mar 27, 2010 5:45 pm
Well it was the right rad i had :o: which is now in (needs secured proper)
Only minor niggles are the abs light is now on and the clutch needs bleed also the reverse light switch isnt working.
But it's alive.
Swear word can be heard as i got a bit excited
http://s250.photobucket.com/albums/gg24 ... 0_1636.flv
Zaust and diff should be do tomorrow along with the fan wiring then its test drive time :woohoo:
leeparkes
Post Sat Mar 27, 2010 7:39 pm
shedrool83 wrote:Swear word can be heard as i got a bit excited
:chuckle: Fuckin ell man!
They sound monstrous dont they 8)
jbh
Hartge Crew
Post Sat Mar 27, 2010 7:45 pm
well done Jake.. It's alive!!! cant wait to see this up close..
gareth
Post Sat Mar 27, 2010 10:15 pm
haha, well done! :D
has anyone fitted a M30 then resisted the temptation to start it without an exhaust? :twisted:
shedrool83
Post Sun Mar 28, 2010 12:41 am
TBH i about sh*t myself when it started 8O >They sound brutal without a zaust attached.
Test drive tomorrow/today cant wait .
jbh
Hartge Crew
Post Sun Mar 28, 2010 2:27 am
gareth wrote:haha, well done! :D
doesn't matter what engine I fit it always gets started first time without the exhaust :twisted: the neighbours love it winkeye
zaust
Zone day release
Post Sun Mar 28, 2010 12:57 pm
I drove mine 10 miles to have the exhaust mated to the maniflods. Sounded awsome in the hatfield tunnel.
Well done btw.
shedrool83
Post Sun Mar 28, 2010 5:52 pm
Zaust done and the clutch is now fine.
Ran out of time so the diff still needs change and the fan was just hooked upto the battery for the test drive.
The temp is alittle to high for my liking(was sitting about 3/4 when driving hard and sat at 1/2 at idle with the fan on) so my have a wee airlock but the heaters are working fine.
Any thoughts?
I must say im impressed with the pulling power in every gear ,it does shift.Gear change is taking a bit of getting used to as the short shift seem alot different now.
Dont think the 1.6 diff will last long so swapping that for the 3.64 will be the next job.
Then tidy up the engine bay and fit a switch for the fan.(what switch are you using if you have one?)
Post Sun Mar 28, 2010 5:55 pm
What will you be using the car for, driving round town, or motorway driving???
Round town driving, 3.64 is great.
Motorway, then a 3.46 is better, you can sit around 100mph at only 3000rpm
BadDave
Post Sun Mar 28, 2010 5:57 pm
shedrool83 wrote: Then tidy up the engine bay and fit a switch for the fan.(what switch are you using if you have one?)
Revotec adjustable fan controller Jake
Fits in the top hose.
Unless you want to wire the one you have through the fusebox and relay for a twin speed setup
shedrool83
Post Sun Mar 28, 2010 6:04 pm
Rav335uk wrote:What will you be using the car for, driving round town, or motorway driving???
The car is only usually used at the weekends and for meets, so a combo of town/motorway really.
It might get used alot more now tho as i reckon it will have my classic wrx/sti in its back pocket
I feel a race coming on winkeye
shedrool83
Post Sun Mar 28, 2010 6:08 pm
Not really sure what to do tbh.
I was just going to wire it to a switch in the dash through a switch live and turn it on/off when needed.
Is this feasible?Will i need a relay or just an inline fuse?
Post Sun Mar 28, 2010 6:19 pm
Don't worry, it'll keep up with a standard scooby winkeye
gcs325i
I'll pilot either chariot for you :D
The car is pretty brutal through the gears, I enjoyed the test drive a lot :lol:
shedrool83
Post Sun Mar 28, 2010 6:26 pm
I'll bring the scooby up with the petrol mate and you can pick your weapon of choice.
Saying that i think you would beat me in lisa's focus lol.
BadDave
Post Sun Mar 28, 2010 7:31 pm
If just opting for the switch, your better with a fuse and wiring it through a relay.
shedrool83
Post Sun Mar 28, 2010 7:38 pm
BadDave wrote:If just opting for the switch, your better with a fuse and wiring it through a relay.
Cheers Dave
gareth
Post Mon Mar 29, 2010 12:21 am
i replicated the original (aircon) fan wiring on mine so it has a slow and fast facility.
what fan do you have again? if you have a E32/4 fan and rad (from and aircon equipped car), you should the two speed switch, relays, fan and resistor to get it all up and running. the actual fan on mine had siezed so i used everything else and now have a spal fan
shedrool83
Post Mon Mar 29, 2010 6:57 am
My air con fan from the e34 was goosed.Ending up fitting a 14" ebay one Gaz had sitting for his m50 conversion.
gareth
Post Mon Mar 29, 2010 10:48 pm
if you still have it lurking, the large resistor (about 10x10x50mm) that's attached is what you'll need for stealthy low speed operation
shedrool83
Post Thu Apr 01, 2010 10:20 pm
We got back at it tonight to change the diff .
The car still had the original diff fitted and it was a struggle to remove but its out.The replacement diff's bolt threads are tight so going to run a tap down them first before its fitted.(Gareth you have pm Re tap size).
Also spotted the e28 rad has a pin hole so thats going to have to be changed :cry: which is a nightmare as it means sourcing another and a drain down again.
Bit pissed off with it atm tbh but we'll get there .
leeparkes
Post Fri Apr 02, 2010 12:15 am
shedrool83 wrote:Also spotted the e28 rad has a pin hole so thats going to have to be changed :cry: which is a nightmare as it means sourcing another
Get it welded :D
gareth
Post Fri Apr 02, 2010 12:18 am
crack an egg in it winkeye
leeparkes
Post Fri Apr 02, 2010 12:21 am
gareth wrote:crack an egg in it winkeye
Aint heard that for years :chuckle:
free range ftw
shedrool83
Post Sun Apr 04, 2010 1:31 pm
Few engine shots .
The bay needs a good clean but will leave that until a few minor issues are addressed.
jbh
Hartge Crew
Post Sun Apr 04, 2010 1:34 pm
what a change in that car Jake.. as said a little under a year ago I bought this as a 316i "pink" touring which needed a lot of work and you and Gaz have turned it around..
gcs325i
Post Sun Apr 04, 2010 2:59 pm
Looks good, glad the relay cover worked out so well.
