Rocker cover cleaning
A1BMW325iSport
- Contact:
try course grade sandpaper then work down to finer grades and finish with some metal polish
your inlet maifold came up very nice tho
mate.... well done
mate.... well done
Tng, are you from Norwich mate?
you won't have seen my car "the other day" as I live in York, but i'm sure I spotted your car a couple of months back coming out of Sweetbriar Ind Est at the lights as I turned in. Was going to L&R Motor Factors for some bits (old fella has an account there
I generally visit Norwich once a month as I have family there, will have to catch up one time
there's a guy who's just joined up who lives in Spixworth too, so a few more zoners around there now. There's a few through in Ispwich too and Kings Lynn also.
Will prob be down early october so I'll PM you nearer the time mate
smithy318i
This guy spent HOURS and hours sanding his cover.
Result... http://www.villagephotos.com/pubbrowse. ... id=1441859
elliot
- Contact:
sure does matey, did it on mine. it goes a bit manky when the foam has dried but after a bit of hose and sponge action, looks greatHyperion wrote:elliot wrote:try a bit of mister muscle oven cleaner, i found it better than a degreaser like gunk.does that really work?
I FOUND THAT THE BEST THING TO USE WAS ALUMINIUM PAINT, IT PICKS UP THE LIGHT BRILLIANTLY AND REALLY SHINES AND YOU CAN GET IN TO ALL THE TIGHT SPOTS THAT A WIRE BRUSH CANT, YOU CAN MAKE ALL THE METAL ENGINE COMPONENTS MATCH, IT IS UNAFFECTED BY HEAT AND STOPS TE ALUMINIUM FROM OXIDISING OVER TIME. A QUICK AND EASY IDEA THAT ONLY COSTS A FEW QUID BUT LOOKS GREAT!
smithy318i
You seem to have CAPS LOCK on mate. Is your keyboard broken?
I reckon if you try some wire wool with Autosol metal polish it will be way on course for a proper shiny bling finish. Then just finish with a cloth with Autosol
