Can I use the E34 M50 gearbox linkage on my conversion or do I need something else?
Also, where can I get a short shift kit?
Stu
Gear linkage
stup86
Parts needed:
M40/M20 ignition coil with high voltage lead
- E30 Zone Meets/Events Team
What conversion are you doing?
tez180
"M50 CONVERSION PARTS REQUIRED: "
Accord Type R
245 Whp
Accord Type R
245 Whp
Never read the toptez180 wrote:"M50 CONVERSION PARTS REQUIRED: "
Cook318IS
iirc, its the e36 m50 325i gearlinkages with the m50/m52 gearbox. I'm waiting for mine to arrive to do it!
It doesnt mention what gearbox is being used, but I suspect it will be the E34 box, in which case no you cant use the linkage unless you chop it up and shorten it as its much to long
stup86
Sorry should of mentioned that.DanThe wrote:It doesnt mention what gearbox is being used, but I suspect it will be the E34 box, in which case no you cant use the linkage unless you chop it up and shorten it as its much to long
I plan to use the engine and box from a '94 E34 525i
So, is it the E36 325i linkage that I need?
Parts needed:
It is indeed
stup86
Great, thanks.
I'll add that to my list of stuff to get.
Parts needed:
stup86
Just been phoning the local breakers for an E36 325i linkage and was told by him that the 320i, 323i, 325i and 328i share the same linkage.
Is this true?
Stu
Is this true?
Stu
Parts needed:
toby
You can check that on realoem.com
No its not true, the 328 upper alloy piece is cranked over at the rear, same as some of the other models I believe, the 325 one is straight which is the type you need
technical01
depends on the shell,.. some smaller four cyclinder engines have the hole for the gear stick in a slighty further forwards position in the floor,
i've just swapped out a m50 in an 318is and neither the 2.5 or the 1.8 gearlinkages fitted,..
had to lengthen the 1.8 or shorten the 2.5
i would expect you could buy a kit,.. or just break out the welder???!,...
this was also e36,. not e30,..
not sure but what with this being e30 zone,. i would exopect it was an e30,...?
