Pls help identify this Inlet Manifold for E30
haffeel
Post Fri Sep 09, 2005 3:18 pm
hello All,
Can any one please identify this inlet manifold belongs to 320i or 325i ?
Big help indeed.
Once identified I shall let you all know the unfolding drama :cry:
thank you all
cheers
here is the picture
Image[/url]
e30_Turbo
Boost Junkie
Post Fri Sep 09, 2005 3:30 pm
I'm thinking it's a 2.0 as they are narrower, but the angle of the pic makes it a little difficult to be sure. Mine is a 2.5 one and my TB looks much bigger than yours :eek:
What lump is that manifold on then?
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Fri Sep 09, 2005 3:36 pm
That is defo a 2.0 mate.
Taylor.
haffeel
Post Fri Sep 09, 2005 4:08 pm
:x
:x
:x
:x
haffeel
Post Fri Sep 09, 2005 4:24 pm
guys, My ride originally an E30 320i,
reacently I changed the engine block (lump) to 325i and the rest all still remain 320i
today I went to a chop shop in search of a 325i Inlet manifold, they told me after looking at my engine bay, my current Inlet manifold is 325i .. and defninitely 320i Inlet manifolds are very different as they have lots of pipes running left and right.
What I wanted is a 325i Inlet Manifold so that I can do BBTB.
Now that you guys tell me this is 320i and the chop shop fellows telling me 325i .. Now I am confused.
here I the photo from another angle
e30_Turbo
Boost Junkie
Post Fri Sep 09, 2005 4:52 pm
The 2.5 and 2.0 are the same shape, look the same, but the internal sizes are different and the 2.5 manifold is more curvy too. You have a 2.0ltre one, probably becasue you had a 2.0ltre before, hence unless you have bought another since, it's still the 2.0ltr one. :mad:
I suggest you check the for sale section or post in the wanted section, there are plenty of 2.5 inlet manifolds around.
You should feel the difference when you fit it too :cool:
BrAdZ
Post Fri Sep 09, 2005 4:59 pm
i have a 2.5 manifold sitting here, would swap with the 2.0 one for nothing :P pm me if your intrested
haffeel
Post Fri Sep 09, 2005 5:03 pm
Ah only now some one tell me, the Inlet Manifold of 2 and 2.5 looks the same :mad:
thanks dude ..
Just one question, can I fix a 2.5 Inlet Manifold from a Left Hand Drice Car to a Right Hand Drive ?
and my next question, by using the AFM that came with 320i , will there be any problem in the 325i Inlet Manifold. This question might sound dumb but I dont want to take any chance.
cheers
:P
stuartgallafant
Post Sun Sep 11, 2005 1:01 pm
Why dont you try and find the part number on the manifold and ring a BMW dealer Parts Dept, and ask them to check the number?
Post Sun Sep 11, 2005 3:25 pm
haffeel wrote:Ah only now some one tell me, the Inlet Manifold of 2 and 2.5 looks the same :mad:
:P
This zone is the source of all E30 knowledge (unlike the US orientated Yahoo E30 group). Ignore all others.
Post Sun Sep 11, 2005 3:31 pm
Yours certainly looks loike a 320 manifold. The kink in the no 1 runner is the give away. More of a smoother curve on the 325. 320 injectors are different than 325 ones as well.
Would be very surprised if there are any problems with a LHD manifold.
The 320i throttle body will strangle your 325 engine.
haffeel
Post Tue Sep 13, 2005 11:53 am
Hi Brian Moore that quote is good enough. I have found 325 Inlet Manifold complete set with throttle body and Injectors. Will be fixing soon
I was just wondering, should I really make it a BBTB? is the bang worth the buck?
Thanks M8
haffeel
