Electric Fan Thermo Switch Rating?
rob0r
Post Mon Mar 22, 2010 11:16 am
I've just about finished my M50 conversion and I'm running the 328i radiator. I have a kenlowe fan bolted up but I haven't finished the wiring. I'm about to order a thermo switch that bolts in the side of the radiator, which is the best temperature range switch to go for? I was thinking 97/85, but any advice would be great.
On/Off
87/82
97/85
100/95
107/97
Here's where I found them...
http://www.cbsonline.co.uk/fans-206-c.asp
Post Mon Mar 22, 2010 12:10 pm
Depends on what temperature thermostat you are using
bimanut
Post Mon Mar 22, 2010 12:16 pm
I`ve just brought a new thermostat and it says 92 degrees on it,will it be ok with the single pole brown sensor?
Post Mon Mar 22, 2010 1:19 pm
I wouldnt recommend using a stat above 88 degrees
bimanut
Post Mon Mar 22, 2010 1:57 pm
Typical!
O well i thought i`d take a punt and brought it off e bay for £3 delivered :)
Original too.
Thought it was a bit high.
