Loom mounting
booomer
Post Fri Mar 19, 2010 8:40 pm
How have people mounted their loom to the bulkhead?
Also what have people used as a box for the ecu (i'm using an e34 loom so the ECU sits on the battery tray)
Post Fri Mar 19, 2010 8:47 pm
Look at cooks thread in the picture gallery
Cook318IS
Post Fri Mar 19, 2010 8:51 pm
I feel famous :o:
4 cylinder wiring cover with e30 m3 cover (just to the left of the 4 cylinder cover) which covers the relays, and an e34 ecu cover(bit infront of the m3 cover). Both the m3 panel, 4 cylinder wiring cover and the e34 ecu cover require some "trimming"
booomer
Post Fri Mar 19, 2010 8:54 pm
Ah nice one, have you got a quick link to your thread to save me searching for hours?
Cook318IS
Post Fri Mar 19, 2010 8:56 pm
searching for hours? :chuckle: its the 4th thread down in the picture gallery section like dan said
http://www.e30zone.net/modules.php?name ... 93&start=0
Alpina99
Post Sun Mar 21, 2010 2:09 pm
So if you're using an E36 loom / ECU would it be best to locate it inside the car behind the dash / glove box ??
Gone, but not forgotten !!
Cook318IS
Post Sun Mar 21, 2010 2:16 pm
An e36 loom is longer than an e34 loom so you can actually still put the ecu behind the dash like a standard e30. Im using an e34 engine with a shorter loom so withought cutting and lengthening the loom i have to have the ecu in the engine bay. If you can keep it inside the car you may as well yeah - reduces the chance of it getting wet.
Alpina99
Post Sun Mar 21, 2010 3:05 pm
Thanks,
That's what I was hoping,
Post Sun Mar 21, 2010 4:57 pm
E36 loom and M3 covers -
Cook318IS
Post Sun Mar 21, 2010 4:58 pm
Dan, your engine bay looks awful - your missing your rocker cover nut clips :P
Post Sun Mar 21, 2010 5:12 pm
Its ok mate I did find them and fit them in the end :)
