Mint condition inner wing...
billgatese30
Post Fri Mar 19, 2010 11:45 am
There is often a little bit of it that needs replacing where the rust has spread to (mine has), but they always need a respray around the lip from where the weld burns the paint. :D
Post Fri Mar 19, 2010 7:19 pm
5 years 8O i remember you being annoying like the other 18 year olds on here!! no names mentioned
now your like a proper old man. That arch is tasty, the other side looks like a good repair, i can confirm having seen the S50 on the ramp its a good proper shell.
Thing is if that arch is like that where else is it f**ked?! they like the salt up north, S50 is a proper southern car :D
skipunda
Post Fri Mar 19, 2010 7:23 pm
billgatese30 wrote: Image
I like the finish on the new arch. What is it?
Chris
billgatese30
Post Fri Mar 19, 2010 8:12 pm
this stuff, goes on excellent with the proper gun and an air compressor
http://www.rejel.com/product/8587.aspx
it is however also available in an aerosol
http://www.rejel.com/product/8589.aspx
billgatese30
Post Fri Mar 19, 2010 8:13 pm
Simon13 wrote:5 years 8O i remember you being annoying like the other 18 year olds on here!! no names mentioned
rest of the car is pretty good still, although there will no doubt be other spots showing up in the next few years.
and I can still be annoying, just in a different way :o
dano0
Post Fri Mar 19, 2010 8:29 pm
i think after spending all that money it would be a shame to keep it hidden in a garage i use mine as a daily and its fine. that arch should last another 20 odd years once its done maybe more if properly protected
nice car by the way
