Days work
snakebrain
Isn't it just coolant cooked onto the engine?bss325i wrote:Its not limescale, its the alloy starting to corrode.
A wire brush and some WD40 will get it off.
Looks like corroded alloy to me as its all over the cam cover and other alloy parts.snakebrain wrote:Isn't it just coolant cooked onto the engine?bss325i wrote:Its not limescale, its the alloy starting to corrode.
Armarni, move the front axel stands to the chassis rails further in from where you have put the axel front stands.
As for some of you, cut him some slack!
Because the vindictive mo fo dragged up bonkers past but didn't have the balls to do it with his user name so opened a second account.Alex wrote:whats wrong with hellbound ive never found him to be off the rails as such
what a prickbss325i wrote:Because the vindictive mo fo dragged up bonkers past but didn't have the balls to do it with his user name so opened a second account.Alex wrote:whats wrong with hellbound ive never found him to be off the rails as such
did you read the bonkers thread at all alex?Alex wrote:whats wrong with hellbound ive never found him to be off the rails as such
+ a yard full of scrap turds
i seen the pics of the m3'smagpie wrote:did you read the bonkers thread at all alex?Alex wrote:whats wrong with hellbound ive never found him to be off the rails as such
couldnt be arsed with reading any of it
i thought how come all these pages, i thought Ratch or Kos must be at it again
what user name did he use??? fancy a read now
Alex wrote:i seen the pics of the m3'smagpie wrote:did you read the bonkers thread at all alex?Alex wrote:whats wrong with hellbound ive never found him to be off the rails as such
his thread lives on,on another forum.
Yes, about 3 pages worth.
That thread has shown a few people in a different light!
- dangerosdave
Looks fine to meAlex wrote:fookin elltunnyx wrote:Am I mistaken or is that sat on the 'pretend jacking points'?magpie wrote:
there not rusty then![]()
- dangerosdave
Ino its addictive ill be back on another name soon alex
- dangerosdave
Its always been sitting on the chassis rail.Im not a Complete plonker.Not much engine work gone on need to get the bit that rotted off the block sorted .Apparently welding is not a good ideamagpie wrote:why hello again^ it's sat on the chassis rail now then.
no more engine work yet?
dangerosdave wrote:Ino its addictive ill be back on another name soon alex
it's royalratch the second..
must admit at least your being constructive now.. less of the immature stuff and your fine..
- dangerosdave
Ill never be let back on here so ill always be on new namesjbh wrote:dangerosdave wrote:Ino its addictive ill be back on another name soon alex
what rusted on the block ?dangerosdave wrote:Its always been sitting on the chassis rail.Im not a Complete plonker.Not much engine work gone on need to get the bit that rotted off the block sorted .Apparently welding is not a good ideamagpie wrote:why hello again^ it's sat on the chassis rail now then.
- dangerosdave
Does the M42 have a alloy head?
If so is alloy weldable?
Yes, and yes.
- dangerosdave
A connector for a hose.It literally came off in the hose
Do you think if i got the same size connector (piece of pipe) welded in its place it would work?Welded by a pro btw
- dangerosdave
Anyone got a pic of an M42 head?
- dangerosdave
http://img.photobucket.com/albums/v297/ ... 200262.jpg
this guy has a bolt in it but it shows the bit in the middle of the 4 inlets
