Wiring loom m50 e30
booomer
Mon Nov 30, 2009 10:54 pm
Hi, when re-wiring an M50 loom with the E30 block connector is it best to leave the wires the same length or should some length be added/taken away?
cheers
booomer
Fri Dec 04, 2009 11:13 am
C'mon loads of people must be able to answer this one?
Fri Dec 04, 2009 12:35 pm
Well, they need to be the right length to reach the body side of the plug
bimanut
Tue Mar 16, 2010 3:42 pm
How have people managed to get the ecu plug through the little round hole?
Its a bit tight and because im using an ex auto i`ve got two plugs.One being a little fater than the other.
I can get the smaller plug through but strugling to get the bigger one on its own,yet alone try to get both in.
Because im not sure which is which,i`m asuming the plug with more wires than the other one is the engine ecu and the other being the gearbox ecu.
I would like to cut the box ecu out but i fear that its a bit more complecated than my (very) basic leccy skills.So it looks like i`m going to have to let the g box ecu plug float around in the engine bay some where. :?
