Please lock or delete
Enter a group buy or look here for zone discounts
rix313
Post Fri Mar 12, 2010 10:42 pm
I recon 2.5 would be best.
Just bought myself a prefacelift rack from Chris-W 8) if the numbers keep growing I'll get it off to Quaife
Any one on any other E30 forums? Might be handy to spread the word and fill the list.
Post Fri Mar 12, 2010 10:48 pm
2.5 will be fooking quick as is.. Nevermind 2.1, I would say 2.1 would be verging on too twitchy..
jbh
Hartge Crew
Post Fri Mar 12, 2010 11:15 pm
Jhonno wrote:2.5 will be fooking quick as is.. Nevermind 2.1, I would say 2.1 would be verging on too twitchy..
I was thinking the same i would go with the 2.5
gareth
Post Fri Mar 12, 2010 11:28 pm
i used to run a 2.2 turn quickrack on a mk2 escort... sublime :D
parking is more fun though but once you're going it's not too bad. you very rarely need to cross hands or anything either which makes it a bit easier
ross_jsy
Post Sat Mar 13, 2010 2:38 am
i would prefer a 2.1, due to the hill climb my car is being built for is very twisty.
but either way, im easy
vladv
Post Sat Mar 13, 2010 2:29 pm
Does that kit fit to lefthand rack?
craigieeb
Post Sat Mar 13, 2010 2:52 pm
1. rix313
2. ross_jsy
3. mattrs
4. Scot
5. jbh
6. dsm2002
7. Motorhole
8. Craig
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
hookedonboost
Post Sat Mar 13, 2010 3:15 pm
1. rix313
2. ross_jsy
3. mattrs
4. Scot
5. jbh
6. dsm2002
7. Motorhole
8. Craig
9. hookedonboost
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
rix313
Post Sat Mar 13, 2010 11:36 pm
I've emailed them to ask if they can do LHD racks too, should know by Monday eve :)
ross_jsy
Post Sun Mar 14, 2010 12:28 am
this is gathering pace nicely
gonna whip the rack off in preperation for it winkeye
mattrs
Post Sun Mar 14, 2010 3:41 pm
Is twenty the magic number then?
rix313
Post Sun Mar 14, 2010 4:48 pm
Yeah it be, although if we get close I will give them a nudge n say come on play ball
ross_jsy
Post Sun Mar 14, 2010 5:12 pm
is this posted on any other forums?
rix313
Post Sun Mar 14, 2010 5:59 pm
I've got it on bmwtrackzone but not any where else to my knowledge be good if it was :)
Motorhole
Post Sun Mar 14, 2010 7:24 pm
hmmm...I better start looking for a pre-facelift manual rack to rebuild :?
gareth
Post Sun Mar 14, 2010 11:10 pm
is it worth putting a link up here too?
http://www.bmw-rallying.co.uk/
vladv
Post Mon Mar 15, 2010 10:03 am
e21Jason wrote:Hi I tried to do a group buy a few years ago so looked into this in detail early cars have a round rack bar which means quaife can cut the teeth, later racks are triangular so you cannot get the teeth cut.
Jason
Jason
Jason, I've compared numbers of racks at realoem.com and haven't find any differences.
http://www.realoem.com/bmw/showparts.do ... 05&lang=en (316i M40 1990year)
vs
http://www.realoem.com/bmw/partgrp.do?m ... 05&lang=en (316 M10 1983year).
What should manual rack be rebuiled in final?
e21Jason
Post Mon Mar 15, 2010 10:15 am
The difference is in the rack internals not something you can see on that digram strip a couple of racks down and have a look
Jason
vladv
Post Mon Mar 15, 2010 10:31 am
e21Jason wrote:The difference is in the rack internals not something you can see on that digram strip a couple of racks down and have a look
Jason
So are there any external differences to choose correct rack?
rix313
Post Mon Mar 15, 2010 6:41 pm
Ok email back from Quaife. They say they can do LHD racks too.
vladv
Post Mon Mar 15, 2010 7:20 pm
rix313 wrote:Ok email back from Quaife. They say they can do LHD racks too.
its great.
Will be donor rack needed to make quick rack or they can do new parts?
rix313
Post Mon Mar 15, 2010 9:06 pm
You will need a complete donor rack. You will then be sent the quick ratio version by Quafie and you fit it to the donor.
vladv
Post Tue Mar 16, 2010 4:40 am
I thought the same. So:
1. rix313
2. ross_jsy
3. mattrs
4. Scot
5. jbh
6. dsm2002
7. Motorhole
8. Craig
9. hookedonboost
10. vladv (LHD version)
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
rhett325i
Post Tue Mar 16, 2010 5:46 am
What all is involved in installing this conversion?
ross_jsy
Post Tue Mar 16, 2010 8:11 am
would imagine dissasembling a standard manual rack and building this into it before installing it on the car.
vladv
Post Tue Mar 16, 2010 9:22 am
here is rebuilding of AE86 rack which my friend did. He bought rebuild kit from Quaife.
Stock contents are in bottom and the Quaife are above.
RobCallow
Post Tue Mar 16, 2010 12:44 pm
1. rix313
2. ross_jsy
3. mattrs
4. Scot
5. jbh
6. dsm2002
7. Motorhole
8. Craig
9. hookedonboost
11. RobCallow
12.
13.
14.
15.
16.
17.
18.
19.
20.
325i Track Project.
heavybelly
Post Tue Mar 16, 2010 6:16 pm
Very interested in one of these.
A couple of things though, what is the rack type Quaife have said it will be for, E21jason says a couple of years ago they didn't have the tooling, what about now?
Also the internals are different but are they interchangeable? I'd imagine it will put people off/slow this down if you need to hunt down a very specific part in order to benefit from a quick rack.
rix313
Post Tue Mar 16, 2010 9:28 pm
It will be made up from a pre-facelift rack, seeing as that's what I've just bought lol!
I believe he was refering to the fact they didn't have tools to be able to cut triangular racks. It is true they don't have the tooling for this rack yet hence why I need 20 people on the list to proceed.
ross_jsy
Post Tue Mar 16, 2010 11:01 pm
dont worry heavybelly, there will be plenty of scrap preface povo spec cars out there to plunder a rack off :)
jbh did you find out if you had 2 pre facelift racks btw?
vladv
Post Wed Mar 17, 2010 7:59 am
rix313, did you consider rebuilding of the powerstering racks? Why just manual?
And one more: sorry for my stupid question but if quife cut the teeth of the rack to make it quicker so I need to supply to them my donor rack to cut it, isn't it?
ross_jsy
Post Wed Mar 17, 2010 8:00 am
because they don't have the tooling to make power steering quick racks
scot
Post Wed Mar 17, 2010 8:19 am
Having a bit of a problem sourcing a manual pre facelift rack! Anybody know where i could get one? Ebay has nowt but power racks at the mo...
ImageStannard Motors SM 2.7 Tech1 Sport refurb in process
scot
Post Wed Mar 17, 2010 8:29 am
Also quick question - with this being a standard e30 rack just having its internals changed this will mean i can still use my 6 branch manifold correct?
ross_jsy
Post Wed Mar 17, 2010 8:33 am
as far as i am aware, yes.
for a rack, try emailing spadge and see if he has any
