M50 swap steps from completion... a few quick Q's
noog
Post Sat Mar 13, 2010 9:00 pm
Hi Guys,
I forgot trottle cable and oxygen sensor from the e34 I had as doner. I understand I need the sensor for any near decent fuel economy is this a wire straight into the ecu plug???? e34 cable or ????
Do any of you have that available I'm or I'll hunt on ebay?
Any help appreciated...
Also
My cabbie fromerly a 320i will be for more relaxed driving style so I'm looking for a low diff 2.7ish or 2.9??
considering the diff case size will I need drive shafts etc or can a low e30 diff do the job with shafts I have.
A mate has parts from an e12 2.8 auto which I'm also gonna check out as to ratio etc. Would this be far too low...
cheers Guys
town325i
Post Sun Mar 14, 2010 8:46 am
throttle cable is £12 odd new from the dealer so not worth looking for a second hand one imo not sure on the diff front when i do this im using an IS gearbox so i can use my E30 LSD
