Hi, Has anyone had a prop shortend? where did you use and how much did it cost ? Need info so I can work out how much I need to do M30 conversion.
ED
Shorting prop
Andy335Touring
Between me and Toby we think you can use an E30 M3 prop with out chopping it with the e30.de mounts. Just depends on what engine position you settle for ?
At the time of doing my conversion i didn't know that the M3 prop would fit so i had the front section of the E34 M30 prop welded to the rear section of the E30 325 prop at http://www.reco-prop.com/ for about 140 quid.
Have a quick look on here for some picys
http://homepage.ntlworld.com/a.law47/33 ... e%202.html
ed325i
Hi, Thanks for the info, I am going to mount the engine as far back as I can without moding the firewall and make my own mounts up.
ED
ED
glenn
- Engine Transplant Services
i did my own.
no problem if you can weld.
i inserted something inside to centralise it then welded it up.
try to keep the joint at one of the ends to minimise imbalance.
it's the second i've done
