Tps on 318i
e30_318i
Post Thu Sep 08, 2005 4:35 pm
have the bmw's got a tps? (throttle postion sensor) on a 318i? could some explain where it is if it has got one?
many thanks
smithy318i
Post Thu Sep 08, 2005 11:17 pm
What's one of them do then?
No sensors on mine! Cable goes from your foot to the manifold. that's it!
Fushion_Julz
Post Fri Sep 09, 2005 12:49 am
Motronic cars (post 1987) have AFM (air flow meter) instead of a throttle position sensor....Measures the volume of air flowing into the engine rather than using the position of the throttle plate to say how wide the throttle is open...
AFM is more accuarate
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Jos
Post Fri Sep 09, 2005 12:58 am
erm, does the M10 not have an AFM, I think it does, and I don't think it has a TPS..
'94 e36 tree climber
e30_318i
Post Fri Sep 09, 2005 2:43 am
what is the little black box unerneath the throttle linkage with a 3-pin plug going into it? i need to wire my progressive nitrous controller in but need to know where!
