Fuel gauge problem.
TheRam
Wed Mar 03, 2010 1:23 pm
Hello there.
My fuel gauge flips to full as soon as i turn on the car (1990 316i).
After a little while (some times long) it settles down to nearish what's in the tank - the needle can flutter a little bit up or down, as if it can't make it's mind up.
The fuel warning light works as normal as far as i can tell so my point is... is there anything i could try that does not lead me to taking the dash out? A fuel tank sensor problem perhaps...?
Kit
tez180
Wed Mar 03, 2010 1:32 pm
First thing would be to check the brass nut on the reverse of the cluster.
TheRam
Wed Mar 03, 2010 4:59 pm
I guessed I'd not get away with it without taking the dash out.
Kit
tez180
Wed Mar 03, 2010 5:12 pm
To be honest it is so simple its worth starting there..
http://home.comcast.net/~cdeegan9/dashb ... ard_1.html
Tedswagon
Wed Mar 03, 2010 5:25 pm
TheRam wrote:I guessed I'd not get away with it without taking the dash out.
Kit
Start with the speedo - shouldn't take you long. Remember if possible to wrap the end of your screw driver in duct tape to stop scratches when prising parts open or apart.
Alternatively only use plastic tools.
Wed Mar 03, 2010 5:53 pm
Tedswagon wrote: when prising parts open or apart.
what needs 'prising open or apart'? Everything is perfectly designed and screwed together.
tez180
Wed Mar 03, 2010 5:56 pm
Yeah, no needs.
Easily pulls away if everything is undone.
