How to measure crank position sensor.
biggee
Tue Mar 02, 2010 7:14 pm
Does anyone know how to obtain a reading from a crank position sensor. I have removed both sensors from the bellhousing and I believe you set the multimeter to ohms.
I have tried touching the end of the sensor with the probe and earthing the other with ignition on and whilst cranking etc but nothing is there.
Cheers.
E30cabalan
Tue Mar 02, 2010 11:46 pm
biggee
Thu Mar 04, 2010 7:57 pm
Thanks for the replies, I am getting a reading from left to right as follows, 947,955,74.
I understand the reading on the first two is good enough however I am unsure about the third. It's the one nearest the fuse box.
