Rear subframe bush void fillers
Enter a group buy or look here for zone discounts
Tue Feb 23, 2010 9:37 am
For those that had some of these last time round you will know how well they work, for those that didnt, if you want to firm up the rear bushes or pass an MOT with shagged bushes then these are what you need.
I had these in my old 4 door and they made an impressive difference on relatively new bushes, when I started driving my chromie I left the original 22 year old bushes in and experienced a lot of rear wheel steer, fitted these and its like new again :D
Here is the old group buy thread - here
These are now lazer cut so are 100% accurate and consistent
Available for E30 or E36 compact/Z3
If I get an order for 20 sets the price to you will be £21 inc 1st class post, they cost more now due to the manufacturing process and obviously the exchange rate is in America's favour at the moment.
So, 20 names please :D
vladv
Tue Feb 23, 2010 11:23 am
what for that stuff and how to install? Ebay link is brocken.
Tue Feb 23, 2010 2:12 pm
Here is a pic of them fitted
Simply remove the lower supporting plate, push these into the bushes and refit the plate. Tools required - 22mm spanner, 5mm hex key and a jack, fairy liquid helps :)
Cook318IS
Tue Feb 23, 2010 2:21 pm
1. Cook
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Francisco
Tue Feb 23, 2010 2:59 pm
1. Cook
2. Francisco
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
tim_haynes
Tue Feb 23, 2010 3:33 pm
Francisco wrote:1. Cook
2. Francisco
3. Tim_Haynes
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
vladv
Tue Feb 23, 2010 5:57 pm
DanThe wrote:Here is a pic of them fitted
Clear) Don't need for powerflex bushes.
Have a good purchase.
leeparkes
Tue Feb 23, 2010 8:57 pm
They sound crackin 8)
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
clarko74
Wed Feb 24, 2010 9:13 pm
Yes please.
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
clarko74
tim_haynes
Thu Feb 25, 2010 4:01 pm
need more guys!!
AussieM20
Sat Feb 27, 2010 5:16 am
I am interested in a set, but being in Australia, is easier for me to buy them direct. Who sells them please?
Regards
Greg
m_jermyn
Sat Feb 27, 2010 7:00 am
Yeah I would be interested but im in Auss too
Sat Feb 27, 2010 9:38 am
Here is the ebay ad
http://cgi.ebay.com/ebaymotors/ws/eBayI ... %3AIT#shId
If you join in with the group buy it will cost an extra £2 for me to post them to Oz, but it would take longer looking at the response so far!
ed325i
Sat Feb 27, 2010 6:45 pm
Will these fit a e28?
Baurluvva
Sat Feb 27, 2010 8:16 pm
+1
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20. :cool:
Dan320is
Sat Feb 27, 2010 10:05 pm
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
da4x4turbo
Sun Feb 28, 2010 1:34 pm
Ok, there has to be a downside to this. These surely can't be used as any sort of long term solution?
I'm willing to be educated on the pros and cons, but to me this looks like "fixing it" in the same way as this:
Surely the best route is to actually change the bushes for either poly or OEM items? :?
I know it's a pain in the ass, it took me two days to do my car, but the end result was totally worth it! :D
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
Sun Feb 28, 2010 1:47 pm
I suppose it depends on how bad the bushes are?
if they are in relatively good shape but tired, then I'm sure this could work quite well ?
ross_jsy
Sun Feb 28, 2010 6:12 pm
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Sun Feb 28, 2010 7:00 pm
da4x4turbo wrote:Ok, there has to be a downside to this. These surely can't be used as any sort of long term solution?
These are not intended as a 'quick fix' they were designed to stiffen up the standard rear bushes, if you fit new standard bushes (which is recommended anyway) they will still have more movement than with these fitted, the idea is you fill the gap and drastically reduce the amount of flex which not only helps on high speed cornering but your bushes will also last ten times longer.
Sure, you can buy some lumps of plastic from powerflex if thats what your into, or spend some major £££ on the BMW motorsport versions to retain the rubber bush characteristics
If you can think of a downside please enlighten us, because I cant. 8)
CHR1S1990
Sun Feb 28, 2010 7:04 pm
wel, you've convinced me :D
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
da4x4turbo
Sun Feb 28, 2010 8:54 pm
DanThe wrote: the idea is you fill the gap and drastically reduce the amount of flex which not only helps on high speed cornering but your bushes will also last ten times longer.
Just like polybushes then. :D
I can't see a downside either, but I know I'm happier with my polybushes than I would be with these.
Even if these had been suggested to me before I fitted my polyurethane items I still wouldn't have wanted them anywhere near my car.
Each to their own though, I can see the benefit of them. They save a lot of work in the short term. I guess that's easily worth £20. :D
Sun Feb 28, 2010 11:44 pm
No, nothing like poly bushes at all....
Maybe you should fit some to that sh1t heap your trying to palm off for over £2k? Would at least make Barclay feel a little bit better knowing you had actually done something worthwhile perhaps
Sun Feb 28, 2010 11:59 pm
DanThe wrote:No, nothing like poly bushes at all....
:rofl:
Mon Mar 01, 2010 12:02 am
All poly bushes do here is transmit alot of vibaration and noise into the car. Thats cool i suppose?
Kos
Mon Mar 01, 2010 2:30 am
dan, put me down for set for the compact mate !
www.pukardesigns.com
IG Pukar.Designs
Mon Mar 01, 2010 8:34 am
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
10. Kos (E36 compact)
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Banjo1981
Mon Mar 01, 2010 8:46 am
DanThe wrote:if you fit new standard bushes (which is recommended anyway)
How easy is this to do?
I think mine are getting to the stage where I need to think about replacing them anyway (clunking over bumps in the rear) so would like to do it all at once if it's not to difficult to do on the drive.
Ant
DHFiS
Mon Mar 01, 2010 8:54 am
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
11. DHFiS
12.
13.
14.
15.
16.
17.
18.
19.
20.
swllt
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
11. Swllt
12.
13.
14.
15.
16.
17.
18.
19.
20.
schnaarf
Mon Mar 01, 2010 10:24 am
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
11. Swllt
12. Schnaarf
13.
14.
15.
16.
17.
18.
19.
20.
DHFiS
Mon Mar 01, 2010 6:14 pm
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
11. Swllt
12. Schnaarf
13. DHFiS
14.
15.
16.
17.
18.
19.
20.
Banjo1981
Mon Mar 01, 2010 6:25 pm
1. Cook
2. Francisco
3. Tim_Haynes
4. leeparkes
5. clarko74
6. Baurluvva
7. Dan320is
8. ross_jsy
9. CHR1S1990
11. Swllt
12. Schnaarf
13. DHFiS
14. Banjo1981
15.
16.
17.
18.
19.
20.
Mon Mar 01, 2010 6:28 pm
Ant
With the special tool its easy, without, not so easy
The noise might be the rear top mounts unless you know they are good
Banjo1981
Mon Mar 01, 2010 6:35 pm
Good point Dan altho they were replaced not long before I brought the car which is why I suspect the bushes.
It's going into the garage on Wednesday to sort some welding they buggered up so I'll get them to give it a once over whilst it's there.
